Hoping someone can assist with this as I am for some reason getting this everytime I fire up my Ubuntu box.
I basically performed a "sudo apt-get update" and received the following info:
Err http://ppa.launchpad.net trusty/main amd64 Packages
  404  Not Found
Err http://ppa.launchpad.net trusty/main i386 Packages
  404  Not Found
Ign http://ppa.launchpad.net trusty/main Translation-en_AU
Fetched 2,064 kB in 24s (85.8 kB/s)
N: Ignoring file 'extra.list.backup' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
W: Failed to fetch http://ppa.launchpad.net/merlwiz79/cinnamon-ppa/ubuntu/dists/trusty/main/binary-amd64/Packages  404  Not Found
W: Failed to fetch http://ppa.launchpad.net/merlwiz79/cinnamon-ppa/ubuntu/dists/trusty/main/binary-i386/Packages  404  Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
I did have cinnamon installed but un-installed. Not sure if I missed something here.
Any help to remove these messages would be much appreciated.
FYI, I am running Unity.
Thanks.
UPDATED
Attempted to run A.B's commands below and received the following issues:
$sudo ppa-purge ppa:merlwiz79/cinnamon-ppa
Updating packages lists
Warning:  apt-get update failed for some reason
PPA to be removed: merlwiz79 cinnamon-ppa
Warning:  Could not find package list for PPA: merlwiz79 cinnamon-ppa
tonyf
  • 2,637
  1. Remove the PPA ppa:merlwiz79/cinnamon-ppa, as it doesn't contain any Trusty packages:
    sudo rm /etc/apt/sources.list.d/merlwiz79-ubuntu-cinnamon-ppa-*.list
    The removal via ppa-purge doesn't work in this case, because there are no Trusty packages
  2. Remove the file extra.list.backup:
    sudo rm extra.list.backup
  3. Remove the entries http://ppa.launchpad.net trusty main:
    • Open the file /etc/apt/sources.list
      sudo nano /etc/apt/sources.list
    • Search and remove the line deb http://ppa.launchpad.net trusty main
  4. Upgrade your system:
    sudo apt-get update
    sudo apt-get upgrade
Fabby
  • 35,017
A.B.
  • 92,125
I just had the same problem and the solution is straightforward:
Just remove the offending ppas. They are found either in /etc/apt/sources.list as lines or in /etc/apt/sources.list.d/ as files.
Now the message will no longer occur on apt-get update ^^
Consider, though, that any packages depending on the just removed ppa (without alternative sources) will get no updates any more...
Fabio
  • 101
