Using all of the solutions described on this site, setting the Grub menu wait time to zero does not work.
I did the following:
sudo cp /etc/default/grub /etc/default/grub.old
sudo gedit /etc/default/grub
Uncommented this line, per instruction.
GRUB_HIDDEN_TIMEOUT="0"
Set this line, per instruction.
GRUB_TIMEOUT="0"
/etc/default/grub now looks like this:
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
#   info -f grub -n 'Simple configuration'
GRUB_DEFAULT="0"
GRUB_HIDDEN_TIMEOUT_QUIET="true"
GRUB_TIMEOUT="0"
GRUB_DISTRIBUTOR="`lsb_release -i -s 2> /dev/null || echo Debian`"
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash profile"
GRUB_CMDLINE_LINUX=""
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL="console"
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE="640x480"
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID="true"
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
Having edited the /etc/default/grub file -->
sudo update-grub
After restarting, Grub wait-time is still set to 10 seconds.
I was able to get the wait time to 1 second with just one simple change. Edited these two lines in /etc/default/grub
#GRUB_HIDDEN_TIMEOUT="0"
GRUB_TIMEOUT="1"
Commented the first back to the default value, and set GRUB_TIMEOUT to "1".
After,
sudo update-grub
This solution works, but my question is:
Where is the trap that resets the TIMEOUT value to 10 seconds when GRUB-TIMEOUT is set to "0".
Maybe one of the "IF" tests in grub.cfg??
Verax
  • 111
RCF
  • 2,127
5 Answers5
This is a bug. The problem is in the file /etc/grub.d/30_os-prober.
As presented here, a workaround is to add the files /etc/grub.d/25_pre-os-prober and /etc/grub.d/35_post-os-prober.
The two files must also be marked as executable to work.
After adding this two files, your modifications to the variable GRUB_TIMEOUT in /etc/default/grub should work as expected.
If you are not dual booting, another workaround is to uninstall os-prober.
25_pre-os-prober:
#! /bin/sh
# file: /etc/grub.d/25_pre-os-prober
set -e
# Save the $timeout and $timeout_style values set by /etc/grub.d/00_header
# before /etc/grub.d/30_os-prober messes them up.
cat << EOF
set timeout_bak=\${timeout}
set timeout_style_bak=\${timeout_style}
EOF
35_post-os-prober
#! /bin/sh
# file: /etc/grub.d/35_post-os-prober
set -e
# Reset $timeout and $timeout_style to their original values
# set by /etc/grub.d/00_header before /etc/grub.d/30_os-prober messed them up.
cat << EOF
set timeout=\${timeout_bak}
set timeout_style=\${timeout_style_bak}
EOF
Verax
  • 111
edwin
  • 3,829
There is an override in grub for when the timeout is 0 seconds to replace it with 10 seconds. Rather than editing grub scripts as other answers recommend you can simply use:
GRUB_HIDDEN_TIMEOUT="0.0"
GRUB_TIMEOUT="0.0"
This will work because the grub overrides will not find "0" to be equal to "0.0".
If you read the documentation at info -f grub -n 'Simple configuration', it is said that GRUB_HIDDEN_TIMEOUT_* is deprecated.
Could you try using instead in /etc/default/grub:
GRUB_TIMEOUT=0
GRUB_TIMEOUT_STYLE=hidden
#GRUB_HIDDEN_TIMEOUT_QUIET="true"
# rest of file unchanged
Run
sudo update-grub
and see if it works or not.
You could double-check in /boot/grub/grub.cfg looking for timeout that the update has correctly been done.
solsTiCe
  • 9,515
Editing /etc/default/grub is insufficient.
The following modifications are also required:
Disable grub timeout using one of these methods:
sudoedit /boot/grub/grub.cfg
comment out these lines (by placing a # at the start of the lines)
#if [ "${timeout}" = 0 ]; then
#set timeout=10
#fi
save the file and exit.
OR (better, as the above would need to be re-done each time the file is generated, which happens whenever update-grub is called):
sudoedit /etc/grub.d/30_os-prober
#if [ "\${timeout}" = 0 ]; then
#set timeout=10
#fi
save, exit and then run sudo update-grub.
Zanna
  • 72,312
I've always been able to get a 0 second time, although a 1 second time isn't much more wasted time. Try changing this line
to this:
GRUB_CMDLINE_LINUX_DEFAULT="quiet"
I don't see anything in this config file that seems out of whack, but you might try this if you're desperate to save 1 second during boot time.
Daniel
  • 3,626
  • 24
  • 46
