I have a Windows 8.1 and Ubuntu14.04 LTS Computers. I want to connect them to each other using Crossover cable so that I could Transfer files from Ubuntu to windows and back. Can anyone tell me how to do that?
Asked
Active
Viewed 6,774 times
- Connect the computers using your crossover cable (may not be necessary most modern ethernet cards should auto negotiate the connection see this Wikipedia article.)
- Setup both computers IPv4 settings:
- On the Ubuntu computer go to network connections and edit your current connection by doing the following:
- Select the IPv4 tab
- Select "manual" from the method drop down box.
- Click the add button
- Enter an address that makes sense like 192.168.1.2
- Enter a netmask that makes sense like 255.255.255.0
- Gateway can be left blank.
- I don't have a Windows 8.1 computer but you should be able to select the network adapter and configure the IPv4 settings.
- Use a different IPv4 address that makes sense like 192.168.1.3
- Use the same netmask
- Verify the connection works by using the ping on the ubuntu computer: open a terminal by pressing Ctrl+Alt+T at the same time. At the prompt, type:
ping 192.168.1.3or the address of the Windows computer. If you get a response, then the connection is working. - To transfer files you have a few choices. Windows file sharing (Samba), FTP, or SCP. I would start with Windows file sharing. Assuming you have the directory on Windows already setup for sharing.
- On the Ubuntu computer open the Files application (this should be a file drawer on the launcher)
- Open the File toolbar at the top.
- Click Connect to server
- Enter the following:
smb://192.168.1.3or the address of the windows computer - Enter your Windows user name and password.
- A new window should open with all the available shares.
Take a look at this guide.
Yet Another User
- 2,721
Carl Trask
- 79
