I have installed fetchmail, procmail and mutt. I am able to see my sentmail but I am not able to see my inbox. This is my ~/.muttrc file
# Boring details
set realname =Aparna
set from = kdasaparna@gmail.com
set use_from = yes
set envelope_from ="yes"
set sendmail="/usr/bin/msmtp"
# If not set in environment variables:
set spoolfile = /var/spool/mail/aparna
# Folders
set folder="~/Mail"                # Mailboxes in here
set record="+sent"                 # where to store sent messages
set postponed="+postponed"         # where to store draft messages
set move=no                        # Don't move mail from the spool.
# Watch these mailboxes for new mail:
mailboxes ! +Fetchmail +slrn +mutt
set sort_browser=alpha    # Sort mailboxes by alpha(bet)
# Order of headers and what to show
hdr_order Date: From: User-Agent: X-Mailer \
          To: Cc: Reply-To: Subject:
ignore *
unignore Date: From: User-Agent: X-Mailer  \
# which editor do you want to use?
# vim of course!
set editor="vim -c 'set tw=70 et' '+/^$' "
set edit_headers          # See the headers when editing
# Aliases
set sort_alias=alias     # sort aliases in alpha order by alias name
# Odds and ends
set markers          # mark wrapped lines of text in the pager with a +
set smart_wrap       # Don't wrap mid-word
set pager_context=5  # Retain 5 lines of previous page when scrolling.
set status_on_top    # Status bar on top.
push <show-version>  # Shows mutt version at startup
macro index,pager I '<shell-escape> fetchmail -v<enter>'
 set mbox_type=Maildir
 macro index c "<change-folder>?<toggle-mailboxes>" "open a different folder"
 macro pager c "<change-folder>?<toggle-mailboxes>" "open a different folder"
set mbox_type=maildir
set mbox="~/mail/inbox/"
set spoolfile="~/mail/inbox/"
set folder="~/mail/"
set record="~/mail/sent/"
set postponed="~/mail/postponed/"
set editor="vim"
set include=ask-yes
set sendmail="/usr/sbin/ssmtp"
My ~/.fetchmailrc file:
poll pop.gmail.com
with proto POP3
user 'kdasaparna@gmail.com'
there with password '*'
is 'Aparna Karuthodi' here
mda "/usr/bin/procmail -d %T"
options
no keep
ssl
sslcertck
sslcertpath /home/aparna/.certs/
My ~/.promailrc file
PATH=/bin:/usr/bin:/usr/local/bin
VERBOSE=off
DEFAULT=/var/spool/mail/aparna
MAILDIR=$HOME/mail
LOGFILE=$HOME/.procmaillog
# Recipes below this comment:
:0:
* ^TOmutt-user
mutt
s3lph
  • 14,644
  • 60
  • 83
I recognise one of my old guides being used here:). mutt would normally create this file for you but you can create the file manually and then set the correct permissions and owners. First create the file:
sudo touch /var/spool/mail/aparna
Then set the correct permissions:
sudo chmod 660 /var/spool/mail/aparna
Finally make sure the ownership is correct:
sudo chown aparna:mail /var/spool/mail/aparna
Test this with ls, on my own system I see the following:
andrew@ilium~$ ls -l /var/spool/mail/andrew
-rw-rw---- 1 andrew mail 30743 Jul 17 15:30 /var/spool/mail/andrew
and you should see something similar when using:
ls -l /var/spool/mail/aparna
And this should be enough to get you going...
andrew.46
  • 39,359
