12
i have apache2 (Server version: Apache/2.4.7 (Ubuntu) Server built: Mar 10 2015 13:05:59), mysql and phpmyadmin.
While accessing php file by http://localhost/ or http://ipaddress
It shows up source code instead of executing.
Ubuntu 14.04 LTS
Anuj TBE
  • 2,546
5 Answers5
19
I can think of 3 possibilities:
  1. You don't have PHP installed. In that case run:
    sudo apt-get install php php-mysql
  2. You have PHP installed but not enabled. You can try running:
    sudo a2enmod php7
    sudo service apache2 restart
  3. You have PHP installed and enabled but you haven't restarted apache.
you need to install libapache2-mod-php sudo apt-get install libapache2-mod-php it is no longer pulled by other packages as a dependency in 14.04 it named libapache2-mod-php5, in 16.04 they dropped the number at the end for a meta package
For Ubuntu 20.04, I had to run:
sudo a2dismod mpm_event
It tells you to restart Apache2, but you don't need to at this point. Then enable php 7.4 using:
sudo a2enmod php7.4
Then restart Apache2: sudo systemctl restart apache2
Hope this helps!
FlyGuy
  • 51
After Upgrading to Ubuntu 17.10 this morning my answer was a combination of Sledge Hammer's and GM-Script-Writer-62850's answer. The exact commands I needed were:
sudo a2enmod php7.1
Rapidmod
  • 276
After upgrading to Ubuntu 20.04 to 22.04, I also faced this problem and after reinstall phpmyadmin not working but i searched for 1-2 hours and finally this work for me. I have php 8.1 and mysql 8.0
sudo add-apt-repository ppa:ondrej/php
sudo apt-get install libapache2-mod-php8.1
sudo a2enmod php8.1
