I am a beginner Ubuntu person. How is it possible when you do an apt-get install [program] that you know what the actual install directory is? After I install a program, I literally have no idea how to nagivate within the terminal to the install directory in order to execute the program & it's very much frustrating me.
john smith
  • 3,161
If it a graphical program, it will be in your menu. If it is a command line application just type the command in your terminal.
To find the location, type
which <command>
Linux organized the file system different then Windows, so packages put files in a range of locations.
See
Panther
  • 104,528
You do not have to enter the install directory to run the program, you just have to enter the command itself.
For example the command ls is located in /bin/ls. However you can run the command just by entering ls in the terminal. If you want to run a GUI application, you can search for the program name from the dash.
Rumesh
  • 1,449
