Is there a way to have Nautilus automatically use my FUSE file systems to (for example) open ISOs as folders, or archives as folders, or what ever other 'locations' FUSE supports?
RolandiXor
  • 51,797
Nautilus can't possibly 'know' any installed fuse driver because the fuse system does not advertise its drivers mount options and whereabouts by itself. There isn't even a common database defined where the installed fuse drivers register themselves yet.
Note also that the gvfs system handles URIs like smb:// while the fuse driver underneath does not, therefore your preferred fuse driver needs to be supported by gvfs first before it can land in nautilus.
However, there are lots of nautilus-action scripts around that may accomplish what you need. And if you can type in the mount options by hand, a xfce-tool named gigolo can help you to keep your fuse mounts bookmarked.
RolandiXor
  • 51,797
aquaherd
  • 6,345
