So I made a huge mistake and accidently removed /var/www/html and cant restart apache2.. is the content of /var/www/html static or can I copy it from somewhere. Ive just started today with installing my first ubuntu 14.04 webserver (took me alot of hours) and have not made a backup because I was finishing the installation proces. I also looked for an command to fix packages, I tried sudo apt-get but it didn't fix the /var/www/html folder unfortunately
Asked
Active
Viewed 5,599 times
As you have just started hopefully there is no important file in /var/www/html.
You can simply make this directory by following command.
sudo mkdir /var/www/html
Additionaly you reconfigure apache2 by following command
sudo dpkg-reconfigure apache2
If you need to recover the deleted files follow this thread on How to recover deleted files?
moonstruck
- 416
