I tried installing mysql using the command
sudo apt-get install mysql-server
then after entering the password, I'm getting the message
Reading package lists... Done
Building dependency tree
E: Unable to locate package mysql-server
Why is this happening, and how can I solve it?
Pandya
  • 37,289
Apart from depeneding on the Repository source. You can try following
sudo apt-get update && sudo apt-get upgrade
Then search for the package using apt-cache.
sudo apt-cache search mysql | grep mysql | more
You will have couple of results and you can choose appropriate one for you. You might need the client or Server (depends on your needs). The result is as below:
    mysql-server - MySQL database server (metapackage depending on the latest version)
    mysql-server-5.5 - MySQL database server binaries and system database setup
    mysql-client - MySQL database client (metapackage depending on the latest version)
 mysql-client-5.5 - MySQL database client binaries
Once you figure out what version of sql is available. You can install it with apt-get.
sudo apt-get install mysql-server mysql-client
Hope this helps. Alos this is the official Mysql Community page to download MySQL Server for different platforms.
The package name it will install is mysql-server-5.6 (the digits are there so you could also install another version; like 5.5). So you can also use ...
sudo apt-get install mysql-server-5.6
I would suggest to update your system if not updated and to check the repositories you have active.
$ sudo apt-get install mysql-server
[sudo] password:
The following packages were automatically installed and are no longer required:
  linux-headers-3.19.0-15 linux-headers-3.19.0-15-generic
  linux-image-3.19.0-15-generic linux-image-3.19.0-7-generic
  linux-image-extra-3.19.0-15-generic linux-image-extra-3.19.0-7-generic
mysql-server should be present on any Ubuntu system by default.
Rinzwind
  • 309,379
Is your sources.list file correct?
By the way; you can install deb package from http://packages.ubuntu.com/ and install it using dpkg -i PACKAGENAME. For ubunut 14.04 you can download it from here.
