*****UPDATE: I have now implemented a hack which solves this problem. I am still looking for help as I don't really consider the hack a solution. I booted shell (alt+f4) once the computer hung-up on a failure to mount cd-room and typed "tail -n 100 /var/log/syslog" to get a better look at the error. It said that the device was reported as busy. This seemed to imply that the install was getting hung up trying to remount the usb it was booting from. To address this I decided to give it a second usb to find that wouldn't be busy. So in short I plugged in a second identical usb with the same image and magically this works now.
If anyone has any idea how to actually solve this problem I am still very interested in a more legitimate solution!
Thanks,
-David
***NOTE: this is completely random, but for whatever reason this issue exclusively occurs for me on devices that have not previously had an OS installed. Once I install an OS, I am able to use a single bootable usb without noteable issues.
I've been trying to get some hardware (which lacks a CD drive) to work with an unattended install of Ubuntu from a USB. I am trying to use the kickstart method, but it currently returns an error: mounting /dev/sda on /media failed: invalid argument
I have the ks.cfg, txt.cfg, and grub.cfg set up as described below. If you could look them over and let me know what I'm doing wrong, I would very much appreciate it.
grub.cfg:
if loadfont /boot/grub/font.pf2 ; then
set gfxmode=auto
insmod efi_gop
insmod efi_uga
insmod gfxterm
terminal_output gfxterm
fi
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
menuentry "Quick Install" {
set gfxpayload=keep
#THIS IS THE LINE I'M WORRIED ABOUT
linux /install/vmlinuz file=/boot/preseed/ubuntu-server.seed quiet ks=boot:/ks.cfg --
initrd /install/initrd.gz
menuentry "OEM install (for manufacturers)" {
set gfxpayload=keep
linux /install/vmlinuz file=/cdrom/preseed/ubuntu-server.seed quiet oem-config/enable=true --
menuentry "Multiple server install with MAAS" {
set gfxpayload=keep
linux /install/vmlinuz modules=maas-enlist-udeb vga=788 initrd=/install/initrd.gz quiet --
menuentry "Check disc for defects" {
set gfxpayload=keep
linux /install/vmlinuz MENU=/bin/cdrom-checker-menu quiet --
menuentry "Rescue a broken system" {
set gfxpayload=keep
linux /install/vmlinuz rescue/enable=true --
txt.cfg:
default install
label install
menu label ^Install Ubuntu
kernel /install/vmlinuz
append file=/preseed/ubuntu-server.seed initrd=/install/initrd.gz ks=boot:/ks.cfg
label cloud
menu label ^Multiple server install with MAAS
append modules=maas-enlist-udeb vga=788 initrd=/install/initrd.gz quiet --
label check
menu label ^Check disc for defects
append MENU=/bin/cdrom-checker-menu vga=788 initrd=/install/initrd.gz quiet --
label memtest
menu label Test ^memory
kernel /install/mt86plus
label hd
menu label ^Boot from first hard disk
localboot 0x80
and finally my ks.cfg:
#Generated by Kickstart Configurator
#platform=x86
#System language
lang en_US
#Language modules to install
langsupport en_US
#System keyboard
keyboard us
#System mouse
mouse
#System timezone
timezone America/New_York
#Root password
rootpw --disabled
#Initial user
user Rattatta --fullname "Rattatta" --iscrypted --password password/
#Reboot after installation
reboot
#Use text mode install
text
#Install OS instead of upgrade
install
#Use CDROM installation media
cdrom
#System bootloader configuration
bootloader --location=mbr
#Clear the Master Boot Record
zerombr yes
#Partition clearing information
clearpart --all --initlabel
#Disk partitioning information
part / --fstype ext4 --size 1 --grow
part swap --recommended
#System authorization infomation
auth --useshadow --enablemd5
#Network information
network --bootproto=dhcp --device=eth0
#Firewall configuration
firewall --disabled
#Do not configure the X Window System
skipx
%packages
nano
openssh-server
open-vm-tools --no-install-recommends
Thanks very much,
David
