I am trying to deploy Openstack in HA environment where there are 3 nodes(controllers) which have charms deployed inside lxcs but I am having difficulty in deploying the charms inside lxcs on specific nodes.
I would like to deploy 3 units of a charm inside lxcs. i.e. juju deploy -n 3 rabbitmq-server
Is there any way I can use the --to flag for this? i.e. juju deploy -n 3 rabbitmq-server --to lxc:0 lxc:1 lxc:2
When using --to, you can't specify -n, sorry. You have to run the command once for each unit, like in a for loop.
First of all you need to make sure that your containers are running: lxc-ls --fancy. If not start them with lxc-start -n lxc:0 --daemon
Then you need to jump into each container with lxc-attach -n lxc:0, make sure you have OpenstackHA installed and running in each one of them (yes, that means installing it 3 times and wasting some bandwidht and disk space)
Once this is done you can do your Openstack stuff for which I admitedly can not help you much.
sмurf
  • 4,750
  • 26
  • 30
If the units have to be places on specific nodes then do not use the num-units flag (-n).
Instead deploy the first unit using the command:
juju deploy rabbitmq-server --to lxc:0
Then add-units accordingly:
juju add-unit rabbitmq-server --to lxc:1
juju add-unit rabbitmq-server --to lxc:2
