I have Ubuntu 10.10 install on my laptop. And I have a lot of data (nealy 40 GB) in the partition where Linux is installed. I cannot move this data to some where else.
If I now try to install Ubuntu 11.04 via USB (I am avoiding Upgrading via package manager because I have had some bad experiences with it), and not 'Format' my linux partition, are there any chances that my data in /home or /home/user1 or /home/user2 will vanish away?
danjjl
  • 6,573
Uthman
  • 1,528
You should never do this kind of thing without having a backup. Ever. But what you should be able to do, is to boot a usb session, delete everything on your root file system except /home and resize it. Then you can create a separate partition for /home and move the files onto it and then install. (Please investigate this before you start doing anything)
But in any case, you should not install a different version of Ubuntu without cleaning the root file system first. It's asking for major problems.
My understanding is that Ubuntu installer is smart enough to remove system files while keeping the /home folder when installing over an existing Ubuntu - to do this you need to make sure Format Partition is NOT checked - see this for more details.
Then again, I am a firm believer in upgrading, as opposed to re-installing. I have a few machines which were continuously upgraded from 7.10 to the current Ubuntu, including a few Betas. There were some hiccups, but mostly caused by trying to do a dist-upgrade from a not completely upgraded system.
Of course, having a backup is always a great idea - even if you're not re-installing your OS.
Sergey
  • 44,353
