I just recently fixed my broadcom driver and it seemed to work out perfectly but when I get too far (about 10 feet away) it automatically disconnects and tries to reconnects again. When it does reconnect the internet is really slow and the process just repeats again. When I was running Win8 this wasn't a problem so not sure if the router is the problem.
Anyways here is my "wireless info script"
########## wireless info START ##########
Report from: 01 Jun 2015 23:33 CDT -0500
Booted last: 01 Jun 2015 16:30 CDT -0500
Script from: 21 May 2015 09:10 UTC +0000
##### release ###########################
Distributor ID: Ubuntu
Description:    Ubuntu 14.04.2 LTS
Release:    14.04
Codename:   trusty
##### kernel ############################
Linux 3.16.0-38-generic #52~14.04.1-Ubuntu SMP Fri May 8 09:43:57 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
Parameters: ro, quiet, splash, vt.handoff=7
##### desktop ###########################
Ubuntu
##### lspci #############################
01:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller [10ec:8136] (rev 07)
    Subsystem: Toshiba America Info Systems Device [1179:ff1e]
    Kernel driver in use: r8169
05:00.0 Network controller [0280]: Broadcom Corporation BCM43142 802.11b/g/n [14e4:4365] (rev 01)
    Subsystem: Lite-On Communications Inc Device [11ad:6655]
    Kernel driver in use: wl
##### lsusb #############################
Bus 002 Device 004: ID 10f1:1a5b Importek
Bus 002 Device 003: ID 0930:0225 Toshiba Corp.
Bus 002 Device 002: ID 0438:7900 Advanced Micro Devices, Inc.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 0438:7900 Advanced Micro Devices, Inc.
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
##### PCMCIA card info ##################
##### rfkill ############################
0: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: no
1: brcmwl-0: Wireless LAN
    Soft blocked: no
    Hard blocked: no
##### lsmod #############################
wl                   6367833  0
cfg80211              494362  1 wl
wmi                    19193  1 toshiba_acpi
##### interfaces ########################
auto lo
iface lo inet loopback
##### ifconfig ##########################
eth0      Link encap:Ethernet  HWaddr <MAC 'eth0' [IF]>
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
wlan0     Link encap:Ethernet  HWaddr <MAC 'wlan0' [IF]>
          inet addr:192.168.1.10  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::1acf:5eff:fef3:893b/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:2750527 errors:0 dropped:0 overruns:0 frame:391027
          TX packets:1775481 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:3810679467 (3.8 GB)  TX bytes:219721426 (219.7 MB)
          Interrupt:32
##### iwconfig ##########################
eth0      no wireless extensions.
lo        no wireless extensions.
wlan0     IEEE 802.11abg  ESSID:"NETGEAR"
          Mode:Managed  Frequency:2.417 GHz  Access Point: <MAC 'NETGEAR' [AC1]>
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Power Management:off
##### route #############################
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         192.168.1.1     0.0.0.0         UG    0      0        0 wlan0
192.168.1.0     0.0.0.0         255.255.255.0   U     9      0        0 wlan0
##### resolv.conf #######################
nameserver 127.0.1.1
##### network managers ##################
Installed:
    NetworkManager
Running:
root       818     1  0 16:30 ?        00:00:05 NetworkManager
##### NetworkManager info ###############
NetworkManager Tool
State: connected (global)
- Device: wlan0  [NETGEAR] -----------------------------------------------------
  Type:              802.11 WiFi
  Driver:            wl
  State:             connected
  Default:           yes
  HW Address:        <MAC 'wlan0' [IF]>
  Capabilities:
    Speed:           65 Mb/s
  Wireless Properties
    WEP Encryption:  yes
    WPA Encryption:  yes
    WPA2 Encryption: yes
  Wireless Access Points (* = current AP)
    Chavez Linares:  Infra, <MAC 'Chavez Linares' [AN1]>, Freq 2437 MHz, Rate 54 Mb/s, Strength 45 WPA WPA2
    ATT9ZzNxPi:      Infra, <MAC 'ATT9ZzNxPi' [AC2]>, Freq 2462 MHz, Rate 54 Mb/s, Strength 34 WPA WPA2
    D553C5:          Infra, <MAC 'D553C5' [AN3]>, Freq 2437 MHz, Rate 54 Mb/s, Strength 22 WPA WPA2
    Chavez Linares-guest: Infra, <MAC 'Chavez Linares-guest' [AN4]>, Freq 2437 MHz, Rate 54 Mb/s, Strength 44
    D76189:          Infra, <MAC 'D76189' [AN5]>, Freq 2462 MHz, Rate 54 Mb/s, Strength 20 WPA WPA2
    *NETGEAR:        Infra, <MAC 'NETGEAR' [AC1]>, Freq 2417 MHz, Rate 54 Mb/s, Strength 59 WPA2
  IPv4 Settings:
    Address:         192.168.1.10
    Prefix:          24 (255.255.255.0)
    Gateway:         192.168.1.1
    DNS:             192.168.1.1
- Device: eth0 -----------------------------------------------------------------
  Type:              Wired
  Driver:            r8169
  State:             unavailable
  Default:           no
  HW Address:        <MAC 'eth0' [IF]>
  Capabilities:
    Carrier Detect:  yes
  Wired Properties
    Carrier:         off
##### NetworkManager.state ##############
[main]
NetworkingEnabled=true
WirelessEnabled=true
WWANEnabled=true
WimaxEnabled=true
##### NetworkManager.conf ###############
[main]
plugins=ifupdown,keyfile,ofono
dns=dnsmasq
[ifupdown]
managed=false
##### NetworkManager profiles ###########
[[/etc/NetworkManager/system-connections/NETGEAR]] (600 root)
[connection] id=NETGEAR | type=802-11-wireless | permissions=user:kong:;
[802-11-wireless] ssid=NETGEAR | bssid=<MAC 'NETGEAR' [AC1]> | mac-address=<MAC 'wlan0' [IF]>
[ipv4] method=auto
[ipv6] method=ignore
##### iw reg get ########################
Region: America/Chicago (based on set time zone)
country US:
    (2402 - 2472 @ 40), (3, 27)
    (5170 - 5250 @ 40), (3, 17)
    (5250 - 5330 @ 40), (3, 20), DFS
    (5490 - 5600 @ 40), (3, 20), DFS
    (5650 - 5710 @ 40), (3, 20), DFS
    (5735 - 5835 @ 40), (3, 30)
    (57240 - 63720 @ 2160), (N/A, 40)
##### iwlist channels ###################
eth0      no frequency information.
lo        no frequency information.
wlan0     32 channels in total; available frequencies :
          Channel 01 : 2.412 GHz
          Channel 02 : 2.417 GHz
          Channel 03 : 2.422 GHz
          Channel 04 : 2.427 GHz
          Channel 05 : 2.432 GHz
          Channel 06 : 2.437 GHz
          Channel 07 : 2.442 GHz
          Channel 08 : 2.447 GHz
          Channel 09 : 2.452 GHz
          Channel 10 : 2.457 GHz
          Channel 11 : 2.462 GHz
          Channel 36 : 5.18 GHz
          Channel 38 : 5.19 GHz
          Channel 40 : 5.2 GHz
          Channel 42 : 5.21 GHz
          Channel 44 : 5.22 GHz
          Channel 46 : 5.23 GHz
          Channel 48 : 5.24 GHz
          Channel 52 : 5.26 GHz
          Channel 56 : 5.28 GHz
          Channel 60 : 5.3 GHz
          Channel 64 : 5.32 GHz
          Channel 100 : 5.5 GHz
          Channel 104 : 5.52 GHz
          Channel 108 : 5.54 GHz
          Channel 112 : 5.56 GHz
          Channel 116 : 5.58 GHz
          Channel 132 : 5.66 GHz
          Channel 136 : 5.68 GHz
          Channel 140 : 5.7 GHz
          Channel 149 : 5.745 GHz
          Channel 153 : 5.765 GHz
          Current Frequency:2.417 GHz (Channel 2)
##### iwlist scan #######################
eth0      Interface doesn't support scanning.
lo        Interface doesn't support scanning.
Channel occupancy:
      1   APs on   Frequency:2.417 GHz (Channel 2)
      1   APs on   Frequency:2.462 GHz (Channel 11)
wlan0     Scan completed :
          Cell 01 - Address: <MAC 'NETGEAR' [AC1]>
                    Channel:2
                    Quality=56/70  Signal level=-54 dBm
                    Encryption key:on
                    ESSID:"NETGEAR"
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s
                              9 Mb/s; 12 Mb/s; 18 Mb/s
                    Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s
                    Mode:Master
                    Extra:tsf=0000000000000000
                    Extra: Last beacon: 68ms ago
                    IE: IEEE 802.11i/WPA2 Version 1
                        Group Cipher : CCMP
                        Pairwise Ciphers (1) : CCMP
                        Authentication Suites (1) : PSK
          Cell 02 - Address: <MAC 'ATT9ZzNxPi' [AC2]>
                    Channel:11
                    Quality=46/70  Signal level=-64 dBm
                    Encryption key:on
                    ESSID:"ATT9ZzNxPi"
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 18 Mb/s
                              24 Mb/s; 36 Mb/s; 54 Mb/s
                    Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 48 Mb/s
                    Mode:Master
                        Group Cipher : TKIP
                        Pairwise Ciphers (2) : CCMP TKIP
                    IE: WPA Version 1
                        Group Cipher : TKIP
##### module infos ######################
[wl]
filename:       /lib/modules/3.16.0-38-generic/updates/dkms/wl.ko
license:        MIXED/Proprietary
srcversion:     9A49255BA90267D99664757
depends:        cfg80211
vermagic:       3.16.0-38-generic SMP mod_unload modversions
parm:           passivemode:int
parm:           wl_txq_thresh:int
parm:           oneonly:int
parm:           piomode:int
parm:           instance_base:int
parm:           nompc:int
parm:           intf_name:string
[cfg80211]
filename:       /lib/modules/3.16.0-38-generic/kernel/net/wireless/cfg80211.ko
description:    wireless configuration support
license:        GPL
author:         Johannes Berg
srcversion:     33ED2C1448F5AEDBE7AF59E
depends:
intree:         Y
signer:         Magrathea: Glacier signing key
sig_key:        C2:84:ED:AC:CF:0B:47:36:52:C3:4D:23:BE:C3:56:94:42:36:E6:3B
sig_hashalgo:   sha512
parm:           ieee80211_regdom:IEEE 802.11 regulatory domain code (charp)
parm:           cfg80211_disable_40mhz_24ghz:Disable 40MHz support in the 2.4GHz band (bool)
##### module parameters #################
[cfg80211]
cfg80211_disable_40mhz_24ghz: N
ieee80211_regdom: 00
##### /etc/modules ######################
lp
rtc
##### modprobe options ##################
[/etc/modprobe.d/blacklist-ath_pci.conf]
blacklist ath_pci
[/etc/modprobe.d/blacklist-bcm43.conf]
blacklist b43
blacklist b43legacy
blacklist ssb
blacklist bcm43xx
blacklist brcm80211
blacklist brcmfmac
blacklist brcmsmac
blacklist bcma
[/etc/modprobe.d/blacklist.conf]
blacklist evbug
blacklist usbmouse
blacklist usbkbd
blacklist eepro100
blacklist de4x5
blacklist eth1394
blacklist snd_intel8x0m
blacklist snd_aw2
blacklist i2c_i801
blacklist prism54
blacklist bcm43xx
blacklist garmin_gps
blacklist asus_acpi
blacklist snd_pcsp
blacklist pcspkr
blacklist amd76x_edac
[/etc/modprobe.d/blacklist-rare-network.conf]
alias net-pf-3 off
alias net-pf-6 off
alias net-pf-9 off
alias net-pf-11 off
alias net-pf-12 off
alias net-pf-19 off
alias net-pf-21 off
alias net-pf-36 off
[/etc/modprobe.d/iwlwifi.conf]
remove iwlwifi \
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod) \
&& /sbin/modprobe -r mac80211
[/etc/modprobe.d/mlx4.conf]
softdep mlx4_core post: mlx4_en
[/etc/modprobe.d/modesetting.conf]
options cirrus modeset=1
options mgag200 modeset=1
##### rc.local ##########################
exit 0
##### pm-utils ##########################
##### udev rules ########################
[/etc/udev/rules.d/70-persistent-net.rules]
# PCI device 0x10ec:0x8136 (r8169)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="<MAC 'eth0' [IF]>", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth0"
# PCI device 0x14e4:0x4365 (wl)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="<MAC 'wlan0' [IF]>", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="wlan*", NAME="wlan0"
##### dmesg #############################
[22738.256347] ERROR @wl_dev_intvar_get : error (-1)
########## wireless info END ############
Pilot6
  • 92,041
