I am trying to enable antispam plugin for dovecot, but then dovecot stops working:
Jun  4 19:31:25 newmail dovecot: imap-login: Login: user=<tomasz_grobelny>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=30714, secured, session=<eNurOLYXuQB/AAAB>
Jun  4 19:31:25 newmail dovecot: imap(tomasz_grobelny): Fatal: master: service(imap): child 30714 returned error 3
How do I track down why "child returned error 3"? Any chance for more verbose logs or being able to attach debugger? Obviously without the antispam plugin everything works just fine.
It may be too late to answer but I bumped into the same problem just now.
You posted your problem here so I assume that you might have ran Dovecot on Ubuntu. The problem is that pipe instead of mailtrain should be used for backend under Debian.
plugin {
  #setting_name = value
  antispam_backend = pipe
  antispam_mail_spam = --spam
  antispam_mail_notspam = --ham
  antispam_mail_sendmail = /usr/bin/sa-learn-pipe.sh
  antispam_spam = Junk
  antispam_trash = Trash
What's more, if you were following the tutorial from http://wiki2.dovecot.org/Plugins/Antispam , the pipe script there lacks several link breaks. So it should be:
#!/bin/bash
echo /usr/bin/sa-learn $* /tmp/sendmail-msg-$$.txt
echo "$$-start ($*)" >> /tmp/sa-learn-pipe.log
#echo $* > /tmp/sendmail-parms.txt
cat<&0 >> /tmp/sendmail-msg-$$.txt
/usr/bin/sa-learn $* /tmp/sendmail-msg-$$.txt && rm -f /tmp/sendmail-msg-$$.txt &
echo "$$-end" >> /tmp/sa-learn-pipe.log
exit 0
