I'm trying to install numpy but the installation keeps failing for some reason.
Actually, what I need is python's nolearn, but numpy (and scipy) are dependencies.
So I ran:
sudo pip install numpy
But this fails with the installation log:
Downloading/unpacking numpy
  Running setup.py (path:/tmp/pip_build_root/numpy/setup.py) egg_info for package numpy
    Running from numpy source directory.
    warning: no previously-included files matching '*.pyc' found anywhere in distribution
    warning: no previously-included files matching '*.pyo' found anywhere in distribution
    warning: no previously-included files matching '*.pyd' found anywhere in distribution
Installing collected packages: numpy
  Running setup.py install for numpy
    /bin/sh: 1: svnversion: not found
    non-existing path in 'numpy/distutils': 'site.cfg'
    non-existing path in 'numpy/f2py': 'docs'
    non-existing path in 'numpy/f2py': 'f2py.1'
    F2PY Version 2
    blas_opt_info:
    blas_mkl_info:
      libraries mkl,vml,guide not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/x86_64-linux-gnu']
      NOT AVAILABLE
    openblas_info:
      FOUND:
        libraries = ['openblas']
        language = f77
        library_dirs = ['/usr/lib']
      FOUND:
        language = f77
    non-existing path in 'numpy/lib': 'benchmarks'
    lapack_opt_info:
    openblas_lapack_info:
    C compiler: cc
    compile options: '-c'
    cc: /tmp/tmpazdxtcf1/source.c
    cc /tmp/tmpazdxtcf1/tmp/tmpazdxtcf1/source.o -lopenblas -o /tmp/tmpazdxtcf1/a.out
      FOUND:
        language = f77
      FOUND:
        language = f77
    unifing config_cc, config, build_clib, build_ext, build commands --compiler options
    unifing config_fc, config, build_clib, build_ext, build commands --fcompiler options
    build_src
    building py_modules sources
    building library "npymath" sources
    customize Gnu95FCompiler
    Found executable /usr/bin/gfortran
    customize Gnu95FCompiler using config
    C compiler: x86_64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -g -fstack-protector-strong -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2 -fPIC
    compile options: '-Inumpy/core/src/private -Inumpy/core/src -Inumpy/core -Inumpy/core/src/npymath -Inumpy/core/src/multiarray -Inumpy/core/src/umath -Inumpy/core/src/npysort -Inumpy/core/include -I/usr/include/python3.4m -c'
    x86_64-linux-gnu-gcc: _configtest.c
    x86_64-linux-gnu-gcc -pthread _configtest.o -o _configtest
    success!
    removing: _configtest.c _configtest.o _configtest
    _configtest.c:1:5: warning: conflicting types for built-in function ‘exp’
     int exp (void);
    _configtest.o: In function `main':
    /tmp/pip_build_root/numpy/_configtest.c:6: undefined reference to `exp'
    collect2: error: ld returned 1 exit status
    failure.
     int exp (void);
    x86_64-linux-gnu-gcc -pthread _configtest.o -lm -o _configtest
    success!
    conv_template:> build/src.linux-x86_64-3.4/numpy/core/src/npymath/npy_math.c
    conv_template:> build/src.linux-x86_64-3.4/numpy/core/src/npymath/ieee754.c
    conv_template:> build/src.linux-x86_64-3.4/numpy/core/src/npymath/npy_math_complex.c
    building library "npysort" sources
    conv_template:> build/src.linux-x86_64-3.4/numpy/core/src/npysort/quicksort.c
    conv_template:> build/src.linux-x86_64-3.4/numpy/core/src/npysort/mergesort.c
    conv_template:> build/src.linux-x86_64-3.4/numpy/core/src/npysort/heapsort.c
    conv_template:> build/src.linux-x86_64-3.4/numpy/core/src/private/npy_partition.h
      adding 'build/src.linux-x86_64-3.4/numpy/core/src/private' to include_dirs.
    conv_template:> build/src.linux-x86_64-3.4/numpy/core/src/npysort/selection.c
    conv_template:> build/src.linux-x86_64-3.4/numpy/core/src/private/npy_binsearch.h
    conv_template:> build/src.linux-x86_64-3.4/numpy/core/src/npysort/binsearch.c
    None - nothing done with h_files = ['build/src.linux-x86_64-3.4/numpy/core/src/private/npy_partition.h', 'build/src.linux-x86_64-3.4/numpy/core/src/private/npy_binsearch.h']
    building extension "numpy.core._dummy" sources
    Generating build/src.linux-x86_64-3.4/numpy/core/include/numpy/config.h
    _configtest.c:1:20: fatal error: Python.h: No such file or directory
     #include <Python.h>
    compilation terminated.
     #include <Python.h>
    failure.
    /usr/lib/python3.4/distutils/dist.py:260: UserWarning: Unknown distribution option: 'define_macros'
      warnings.warn(msg)
    Traceback (most recent call last):
      File "<string>", line 1, in <module>
      File "/tmp/pip_build_root/numpy/setup.py", line 251, in <module>
        setup_package()
      File "/tmp/pip_build_root/numpy/setup.py", line 243, in setup_package
        setup(**metadata)
      File "/tmp/pip_build_root/numpy/numpy/distutils/core.py", line 169, in setup
        return old_setup(**new_attr)
      File "/usr/lib/python3.4/distutils/core.py", line 148, in setup
        dist.run_commands()
      File "/usr/lib/python3.4/distutils/dist.py", line 955, in run_commands
        self.run_command(cmd)
      File "/usr/lib/python3.4/distutils/dist.py", line 974, in run_command
        cmd_obj.run()
      File "/tmp/pip_build_root/numpy/numpy/distutils/command/install.py", line 62, in run
        r = self.setuptools_run()
      File "/tmp/pip_build_root/numpy/numpy/distutils/command/install.py", line 36, in setuptools_run
        return distutils_install.run(self)
      File "/usr/lib/python3.4/distutils/command/install.py", line 583, in run
        self.run_command('build')
      File "/usr/lib/python3.4/distutils/cmd.py", line 313, in run_command
        self.distribution.run_command(command)
        cmd_obj.run()
      File "/tmp/pip_build_root/numpy/numpy/distutils/command/build.py", line 39, in run
        old_build.run(self)
      File "/usr/lib/python3.4/distutils/command/build.py", line 126, in run
        self.run_command(cmd_name)
        cmd_obj.run()
      File "/tmp/pip_build_root/numpy/numpy/distutils/command/build_src.py", line 153, in run
        self.build_sources()
      File "/tmp/pip_build_root/numpy/numpy/distutils/command/build_src.py", line 170, in build_sources
        self.build_extension_sources(ext)
      File "/tmp/pip_build_root/numpy/numpy/distutils/command/build_src.py", line 329, in build_extension_sources
        sources = self.generate_sources(sources, ext)
      File "/tmp/pip_build_root/numpy/numpy/distutils/command/build_src.py", line 386, in generate_sources
        source = func(extension, build_dir)
      File "numpy/core/setup.py", line 432, in generate_config_h
        moredefs, ignored = cocache.check_types(config_cmd, ext, build_dir)
      File "numpy/core/setup.py", line 42, in check_types
        out = check_types(*a, **kw)
      File "numpy/core/setup.py", line 293, in check_types
        "Cannot compile 'Python.h'. Perhaps you need to "\
    SystemError: Cannot compile 'Python.h'. Perhaps you need to install python-dev|python-devel.
    Complete output from command /usr/bin/python3.4 -c "import setuptools, tokenize;__file__='/tmp/pip_build_root/numpy/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-lsbot4u_-record/install-record.txt --single-version-externally-managed --compile:
F2PY Version 2
blas_opt_info:
blas_mkl_info:
  NOT AVAILABLE
openblas_info:
  FOUND:
    language = f77
  FOUND:
    language = f77
lapack_opt_info:
C compiler: cc
creating /tmp/tmpazdxtcf1/tmp
creating /tmp/tmpazdxtcf1/tmp/tmpazdxtcf1
  FOUND:
    language = f77
  FOUND:
    language = f77
running install
running build
running config_cc
running config_fc
running build_src
build_src
creating build
creating build/src.linux-x86_64-3.4
creating build/src.linux-x86_64-3.4/numpy
creating build/src.linux-x86_64-3.4/numpy/distutils
success!
 int exp (void);
failure.
 int exp (void);
success!
creating build/src.linux-x86_64-3.4/numpy/core
creating build/src.linux-x86_64-3.4/numpy/core/src
creating build/src.linux-x86_64-3.4/numpy/core/src/npymath
creating build/src.linux-x86_64-3.4/numpy/core/src/npysort
creating build/src.linux-x86_64-3.4/numpy/core/src/private
 #include <Python.h>
 #include <Python.h>
failure.
  warnings.warn(msg)
    setup_package()
    setup(**metadata)
    dist.run_commands()
    cmd_obj.run()
    cmd_obj.run()
    old_build.run(self)
    cmd_obj.run()
Cleaning up...
Command /usr/bin/python3.4 -c "import setuptools, tokenize;__file__='/tmp/pip_build_root/numpy/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-lsbot4u_-record/install-record.txt --single-version-externally-managed --compile failed with error code 1 in /tmp/pip_build_root/numpy
Storing debug log for failure in /home/mikel/.pip/pip.log
It says there Perhaps you need to install python-dev|python-devel but I don't. When I try to install python-dev it says:
python-dev is already the newest version.
My guess is that the source of the problem is the warning:
 int exp (void);
But I have no clue on how to tackle this.
Madhav Nikam
  • 2,967
Only the old version can be installed with pip. You may wish to install the latest version with git.
The short version is:
sudo apt-get install python3.4-dev
git clone git@github.com:dnouri/nolearn.git
cd nolearn
pip install -r requirements.txt
python setup.py develop
This should install including all requirements.
You also need the python 3.4 development package.
Sources:
https://github.com/dnouri/nolearn
https://stackoverflow.com/questions/24892810/python-3-4-and-2-7-cannot-install-numpy-package-for-python-3-4
Elder Geek
  • 36,752
