I have previously posted a question in which solsTiCe showed me how to setup a swap on a GPT partition. It worked for a while but now I am having problems again. The swap was not detected again. I followed the exact same advice but it doesn't work this time. After reboot it comes up with cryptswap message asking if I want to skip mounting etc. After logging in free shows no swap, sudo fdisk -l shows the following output:
WARNING: GPT (GUID Partition Table) detected on '/dev/sda'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sda: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders, total 1953525168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk identifier: 0x055144b6
Device Boot Start End Blocks Id System
/dev/sda1 1 1953525167 976762583+ ee GPT
Partition 1 does not start on physical sector boundary.
Disk /dev/mapper/cryptswap: 7999 MB, 7999586304 bytes
255 heads, 63 sectors/track, 972 cylinders, total 15624192 sectors
Disk identifier: 0xe001aed0
Disk /dev/mapper/cryptswap doesn't contain a valid partition table
blkid has the exact same output as the previous question, and so does sudo gdisk /dev/sda.
Output of /etc/fstab/ is:
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda8 during installation
UUID=775b2ce6-e738-40e5-828f-eccdf49cd63a / ext4 errors=remount-ro 0 1
# /boot/efi was on /dev/sda2 during installation
UUID=B639-EA4B /boot/efi vfat defaults 0 1
# /home was on /dev/sda10 during installation
UUID=22c6084f-1225-48eb-a295-5d1a0d3d8830 /home ext4 defaults 0 2
# /windows was on /dev/sda7 during installation
UUID=6D02-3AEA /windows vfat utf8,umask=007,gid=46 0 1
# swap was on /dev/sda9 during installation
#UUID=cfa1562c-1530-4bf6-85c0-babe65ae4e05 none swap sw 0 0
#/dev/mapper/cryptswap1 none swap sw 0 0
/dev/mapper/cryptswap none swap defaults 0 0
and /etc/crypttab is:
#cryptswap1 UUID=cfa1562c-1530-4bf6-85c0-babe65ae4e05 /dev/urandom swap,cipher=aes-cbc-essiv:sha256
cryptswap /dev/sda9 /dev/urandom swap,cipher=aes-cbc-essiv:sha256,size=256
