I have upgraded my Ubuntu to 15.04 from 14.x and I find that I have to manually mount the secondary drive for it to become operational. This is a pain since my /Downloads folder has been directed (by me) to this drive. There seems to be a way by editing /etc/fstab but I do not recall having to do this in the previous installation. Am I missing a simpler way?
Asked
Active
Viewed 6,594 times
The editing of the file is simple.
Open a terminal and edit your
fstab:sudo nano /etc/fstabAdd a line, eg:
UUID=a61d6eab-d90d-471a-8e9c-e9816b6c90cf /home ext4 defaults 0 2Open a second terminal and run the command:
sudo blkidHere is a sample output
% sudo blkid /dev/sdb1: UUID="d89ae699-b2e9-4442-a292-4f27d36d3a9a" TYPE="swap" PARTUUID="000a178e-01" /dev/sdb3: UUID="a61d6eab-d90d-471a-8e9c-e9816b6c90cf" TYPE="ext4" PARTUUID="000a178e-03" /dev/sda1: UUID="d94f4097-91fe-4e96-89b2-7877065d0650" TYPE="ext4" PARTUUID="00096da5-01"Search your partition in the first column, eg.
/dev/sda2. Take theUUIDand replace theUUID(without the double quotes) in the added line in yourfstabfile.- Take the type
TYPEfor the partition and replace the type in thefstabfile. - Replace the example
/homein yourfstabwith your preferred mount point. - Save the
fstabfile - Mount the partition with
sudo mount <your_mount_point>
A.B.
- 92,125
It should not be difficult to mount your drive through fstab. Since you can manually mount it, I assume you have a mount point directory for it in /media. So just add a line to fstab like:
UUID=<whatever> <mountpoint> <file system> defaults 0 0
then issue the command
sudo mount -a
Note: you can obtain the UUID by
sudo blkid
Organic Marble
- 24,696
