Since one week ago, my internet connection suffers constantly interruptions. It works, it goes away, it works, it goes away.
I have Ubuntu 15.04 and until now it had everything worked fine. Any idea? What should I do?
Other devices connected to the wifi work fine
Pilot6
  • 92,041
Jose
  • 61
This question seems to be similar: My pc is disconnecting automatic from wi-fi and I have tried the solution offered:
Replace Network Manager with Wicd:
sudo apt-get install --reinstall wicd
sudo service network-manager stop
sudo apt-get remove --purge network-manager network-manager-gnome
sudo service wicd restart
And reboot your machine.
This solved the problem for me. Since then I've tried changing back to network-manager once, but then the connection problems returned immediately. Wicd has worked flawless ever since.
There was just one more problem to tackle. I use a Cisco VPN connection quite a lot and Wicd doesn't support that out of the box. So, I needed a vpnc client. Wicd is not as easy as Network-manager in that respect, but the following websites helped me getting that to work as well:
https://help.ubuntu.com/community/VPNClient
http://sourceforge.net/projects/vpnc-gui/
Hope this will help you as well.
Tom
  • 31
Try disabling Mobile Broadband from the network menu.
That did the trick for me.
See screenshot below:
Parto
  • 15,647
Tom
  • 31
