I reinstall Ubuntu, and in partitioning remove root and create new root and install, after install my home information goto a new volume mounted and my home empty and my home capacity equal with root. ? how to change to back, and create home and transform information to home ?
Digicom
  • 61
You may try TestDisk to recover lost partitions. It won't help at all, it you have already rewrote the partition... if you just modified the partition table, it will help.
Backup is important
You just need to back up (copy to an external location) your /home/YOUR_USERNAME directory, then restore it back. You can use a simple USB stick (but don't think that that is a forever lasting one). Very important data should be backed up regularly, etc... I'm using Cloud for example (Google Drive, Dropbox, ...)
If you need further help, refer to this documentation: HomeFolder or BackupYourSystem.
antivirtel
  • 3,685
First you mount your old /home to some safe mount point (e.g. /media/old_home) to check if the new installations user and group file system permissions are consistent with the user those of your old /home If this is the case you need to edit /etc/fstab to mount it automatically at boot time as /home. If you have anything of value on the new installations /home (in the / partition - as soon you mount something else to /home it will still be on the disk but not accessible) make a backup and copy it later on to your /home
see: man fstab man mount about file system permissions also see: /etc/passwd /etc/groups
variona
  • 303
