Python comes in two versions: Python 2.7.6 which has now been superseded by Python 3.4.0. The critical line in Python to access MySQL is "import MySQLdb"
Thanks to a response from StackOverFlow, I realized that I was unintentionally accessing MySQL through Python version 2.7.6. Apparently, "MySQLdb" is not compatible with Python version 3.4.0.
Searching the internet has disclosed alternatives for connecting Python to MySql, however, many of the suggestions do not disclose whether the offered solutions would actually work with Python version 3.4.0.
This StackOverFlow Post listed some possible solutions. Python 3.4.0 with MySQL database. I installed mysqlclient 1.3.6, I also ran "sudo pip install PyMySQL" with out error.
However, upon entering python with "python3"; I still received the error message "ImportError: No module named 'MySQLdb'" after typing in: "import MySQLdb". So something was still wrong.
As an FYI MySQL evidently has its own connector, but I don't know whether it works or does not work with Python 3.4. Connecting to MySQL Using Connector/Python I will have to look into this more.
Any advice on how to connect Python 3.4 with MySQL?
Steve R.
  • 418
Best way to connect to MySQL from python is to Use MySQL Connector/Python because it is official Oracle driver for MySQL for working with Python and it works with both Python 3 and Python 2.
install connector using pip
pip install mysql-connector-python
if pip fails you can download the installer from https://dev.mysql.com/downloads/connector/python/
unpack the downloaded DEB file and install it. Refer to this article to download MySQL connector Python and Connect to MySQL
Vishal
  • 196
The documentation for MySQL Connector/Python says Version 2.0 should work with MySQL Server 5.5-5.7 and Python 3.3 and later. So I would say it's a good bet. If it doesn't work, follow up with what error you encounter and I'll see if I can help.
Synergist
  • 315
