END RESULT******Netgear WNDA 3100 wifi stick will only connect to a network with no password.******
I am finding solutions all over the web, I have been searching for hours. However the people that are asking understand Ubuntu, so the steps how to get to and apply the solutions are never discussed. I convinced a friend to convert to Ubuntu from Winblows and I can't get the USB wifi stick to work. I found a solution that sounds like it would fix the problem, I just need help with "Linux for dummies" help:
"I have the same issue here (UQAM), it should have a certificate but, it does not. When you connect for the first time, it wont set it properly so, you need to go to /etc/NetworkManager/system-connections and find your connection name, edit the file. You should see this line:
system-ca-certs=true
change it to
system-ca-certs=false"
This is the website I found that from: https://help.ubuntu.com/community/NetworkManager#Editing_Network_Settings_in_nm-connection-editor
Now I know this shows as a solution for a certificate issue, however I've seen other people use that solution to fix the password glitch.
$ lsusb
Bus 001 Device 004: ID 0846:9011 NetGear, Inc. WNDA3100v2 802.11abgn [Broadcom BCM4323]
$ iwconfig
eth0      no wireless extensions.
wlan0     IEEE 802.11g  ESSID:off/any
          Mode:Managed  Frequency:2.412 GHz  Access Point: Not-Associated
          Bit Rate:300 Mb/s   Tx-Power:32 dBm
          RTS thr:2347 B   Fragment thr:2346 B
          Power Management:off
          Link Quality:0  Signal level:0  Noise level:0
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
lo        no wireless extensions.
roy@roy-Inspiron-620:~$ cat /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
iface lo inet loopback
Pilot6
  • 92,041
There is no compatible linux driver for this adapter. A Windows driver can be installed this way.
Do this in terminal
sudo apt-get purge bcmwl-kernel-source
sudo apt-get install ndiswrapper-common ndiswrapper-utils-1.9 ndiswrapper-dkms
wget http://wikidevi.com/files/Drivers/Broadcom/bcm4323x_5.10.79.30_XP.zip
unzip bcm4323x_5.10.79.30_XP.zip -d bcm4323
cd bcm4323
sudo ndiswrapper -i bcmwlhigh5.inf
sudo ndiswrapper -m
sudo modprobe ndiswrapper
But it seems that there is no way to connect to WPA secure networks.
The only solution is to replace this dongle with something else, if security is vital. WEP may work, but it is not very much secure.
Pilot6
  • 92,041
