I am trying to install pipelight onto my notebook.
Sadly I can't manage to get it installed. Every try to install it ends up with: Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation:
pipelight-multi : Depends: wine-staging
I have spent several hours in the internet, really tried everything to get this fixed - still nothing seemed to work.
I would post my sources-list and sources-list-d, but this results in an error on this page, since my post would contain more than 1 link then.
As just said, I really tried nearly everything.
Stuff like:
sudo apt-get -f install
Results in:
0 upgraded, 0 newly installed, 0 to remove and 0 not upgrade
Is there anything I can do to fix this issue? Clearing apt-cache doesn't work, doing dist-upgrades, purging the PPAs.. Nearly visited every single result in google on the first two pages, tried everything - still can't get this to work.
Thanks!
JoKeR
  • 7,062
Although this question is old, I thought I'd add some useful info for anything after 15.10, but also for the original question. It seems after 16.04 there is no more pipelight build, so after that it's possible to take the deb from here and make sure the dependencies are met:
https://launchpad.net/~pipelight/+archive/ubuntu/stable/+build/9708266
To meet the dependency wine-staging , one can use the WineHQ PPA as described here:
sudo dpkg --add-architecture i386
wget -qO- https://dl.winehq.org/wine-builds/winehq.key | sudo apt-key add -
sudo apt-add-repository 'deb http://dl.winehq.org/wine-builds/ubuntu/ bionic main'
(replace bionic by any other name for your version if that's older, or upgrade to latest LTS)
then:
sudo apt install wine-staging
then from the folder with your downloaded deb:
sudo dpkg -i pipelight-multi_0.2.8.2_ubuntu16.04.1_amd64.deb
(might need sudo apt --fix-broken install afterwords if terminal feedback shows that). Mind the terminal output that says to activate the license with:
touch $HOME/.config/wine-wininet-installer.accept-license
Installing wine as described should give you what you need and answer this question. I hope that helps you. You may need an older firefox version to get the plugin working (before Firefox 52).
kenorb
  • 10,944
If you run one of this Ubuntu versions
  • Ubuntu 15.10
  • Ubuntu 15.04
  • Ubuntu 14.10
  • Ubuntu 14.04
  • Ubuntu 12.04
than follow the steps below
  1. Remove the package pipelight-multi
    sudo apt-get purge pipelight-multi
  2. Add the PPA ppa:pipelight/stable
    sudo apt-add-repository ppa:pipelight/stable
  3. Update the package information
    sudo apt-get update
  4. Install pipelight
    sudo apt-get install pipelight-multi
A.B.
  • 92,125
I had the exact same problem in Ubuntu 15.10. The following command fixed the issue for me:
Just in case, here are all commands i ran in chronological order:
sudo apt-get update
sudo apt-get install --install-recommends pipelight-multi
Bernd
  • 198
