I installed Xubuntu 15.04 with Xfce 4.12.
I would like to use KWin as the window manager.
With previous versions of Xfce and KWin replacing xfwm with kwin was pretty straightforward, but now both Xfce and Kwin seem to have changed significantly and old instructions (see for instance: here) are not valid anymore.
Additional notes:
With in KWin5, the program
kwinhas been replaced bykwin_x11andkwin_wayland.If I run
kwin_x11 --replace, I get no decorations.If I try to install
kwin-style-qtcurve(as indicated here for an older Xfce), I get a dependency problem onlibkdecorations4abi2:$ sudo env LANG=en_US apt-get install kwin-style-qtcurve ... Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: kwin-style-qtcurve : Depends: libkdecorations4abi2 (>= 4:4.11.1) but it is not installable Recommends: kde-style-qtcurve but it is not going to be installed E: Unable to correct problems, you have held broken packages.
