i can run my wifi card (rtl8188eu) in ap mode in windows by using Realtek Wireless LAN Utility or Connectify.. But When i tried in ubuntu i got an error saying..
(32) Access Point (AP) mode is not supported by this device
How to fix this?
UPDATE: How did i try to set up an ap..
I used Network manager to create an wifi infrastructure network "Wi-Fi connection 1" and change the field mode=infrastructure to mode=ap in file /etc/NetworkManager/system-connections/Wi-Fi connection 1. and tried connecting to that network via connect to hidden network.
Edit: i just need to share my Wired Internet to other wifi deviecs through my wifi card.. not to connectify...
Sijin T V
  • 582
It is possible.
I only know the method with hostapd to create an AP.
And to use hostapd with rtl8188, you need to use a patched version of hostapd. There are several version floating around. Look for rtl8188 and raspbian and hostapd in your favorite search engine.
For example here or here
But extra step is needed to make the bridge to share internet connection.
To ease things, I recommend to use create_ap that will do it in one step. See https://github.com/oblique/create_ap
solsTiCe
  • 9,515
you have to install new modules, then AP will works fine:
philipp@d3pi2:~ $ modinfo r8188eu
filename:       /lib/modules/5.4.51-v7l+/kernel/drivers/staging/rtl8188eu/r8188eu.ko
firmware:       rtlwifi/rtl8188eufw.bin
version:        v4.1.4_6773.20130222
author:         Realtek Semiconductor Corp.
description:    Realtek Wireless Lan Driver
license:        GPL
philipp@d3pi2:~ $ sudo su - root@d3pi2:~/rtl_drw# mkdir rtl_drw; cd rtl_drw;
root@d3pi2:~/rtl_drw# wget http://downloads.fars-robotics.net/wifi-drivers/8188eu-drivers/8188eu-5.4.51-v7l-1333.tar.gz root@d3pi2:~/rtl_drw# tar -xzf 8188eu-5.4.51-v7l-1333.tar.gz root@d3pi2:~/rtl_drw# ./install.sh root@d3pi2:~/rtl_drw# reboot
philipp@d3pi2:~ $ modinfo 8188eu filename: /lib/modules/5.4.51-v7l+/kernel/drivers/net/wireless/8188eu.ko version: v5.3.9_28540.20180627 author: Realtek Semiconductor Corp. description: Realtek Wireless Lan Driver license: GPL
philipp@d3pi2:~ $ sudo iwconfig wlan1 wlan1 IEEE 802.11bgn ESSID:"PUTIN_KHUILO" Nickname:"putinkhuilo" Mode:Master Frequency:2.412 GHz Access Point: 20:0D:C0:21:EC:E8 Bit Rate:72.2 Mb/s Sensitivity:0/0 Retry:off RTS thr:off Fragment thr:off Encryption key:off Power Management:off Link Quality:0 Signal level:0 Noise level:0 Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:0 Invalid misc:0 Missed beacon:0
