I am running XUbuntu 14.04 and today I issued sudo apt-get upgrade on my system and the output was
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n]
Setting up sagemath-upstream-binary (6.7ppa7) ...
Running Sage once as root to set paths
│ SageMath Version 6.7, Release Date: 2015-05-17                     │
│ Type "notebook()" for the browser-based notebook interface.        │
│ Type "help()" for help.                                            │
Traceback (most recent call last):
File "/usr/lib/sagemath/src/bin/sage-ipython", line 7, in <module>
from sage.repl.interpreter import SageTerminalApp
File "/usr/lib/sagemath/local/lib/python2.7/site-packages/sage/__init__.py", line 3, in <module>
from sage.repl.ipython_extension import load_ipython_extension
File "/usr/lib/sagemath/local/lib/python2.7/site-packages/sage/repl/ipython_extension.py", line 59, in <module>
from IPython.core.magic import Magics, magics_class, line_magic
File "/usr/lib/sagemath/local/lib/python2.7/site-packages/IPython/__init__.py", line 45, in <module>
from .config.loader import Config
File "/usr/lib/sagemath/local/lib/python2.7/site-packages/IPython/config/__init__.py", line 6, in <module>
from .application import *
File "/usr/lib/sagemath/local/lib/python2.7/site-packages/IPython/config/application.py", line 9, in <module>
import json
File "/usr/lib/sagemath/local/lib/python/json/__init__.py", line 108, in <module>
from .decoder import JSONDecoder
File "/usr/lib/sagemath/local/lib/python/json/decoder.py", line 5, in <module>
import struct
File "/usr/lib/sagemath/local/lib/python/struct.py", line 1, in <module>
from _struct import *
ImportError: No module named _struct
dpkg: error processing package sagemath-upstream-binary (--configure):
subprocess installed post-installation script returned error exit status 1
It appears that there is something wrong with sage and indeed issuing sage returns
import json
import struct
Does anyone have an idea what is wrong with my system? If so, how can I fix it?
Calcius
  • 238
It looks like there is a problem in the build uploaded to the mirror. They are trying to fix it. A temporary fix is to revert back to a previous version by using the following command
sudo apt-get install sagemath-upstream-binary=6.6ppa1
sudo apt-mark hold sagemath-upstream-binary
For more information about it go to This link. You can also follow the discussion there as they will post the fix when it is done.
Calcius
  • 238
Well it appears a single application is causing this problem from lack of dependencies and/or broken packages. This can happen from time to time.
As a possible fix you can try copying and executing the script below to see if it re-mediates your problem. Since the script does not pass control back to the command-line-interface, as running individual commands does, the package manager should build and fix the dependencies as the script is executed with out having broken packages.
#! /bin/bash
sudo apt-get update
sudo apt-get -f install -y
sudo updatedb
sudo apt-get -f upgrade -y
sudo updatedb
exit
Copy the script into gedit and save it. Then from command line, change the mode of access to executable and execute the script using the sudo command:
:~$ chmod +x scriptname.sh
:~$ sudo ./scriptname.sh
If this does not re-mediate your problem, purge sage and it will remove all your dependencies for the application. Then reinstall sage.
:~$ sudo apt-get purge sage
:~$ sudo apt-get autoremove -y
:~$ sudo apt-get install sage
NOTICE: I did not put the -y flag on the apt-get purge sequence because sage could be linked to ubuntu-desktop package which inturn will take your whole desktop environment. To avoid this you will be prompted with a (Yes/No) option. If you see *XUbuntu-desktop as one of the packages to be removed then enter no as the option.
If this not successful re-post and the Ubuntu Universe will help you with another work around!
Good Luck and Go Ubuntu!
oOpSgEo
  • 539
