I can't get users other than me or root to access the files on a mounted NTFS partition. The answers I've found to similar questions usually mention to set the uid and gid options. In my situation I mount the partition with ntfs-3g and have a UserMapping file defined in the default location. As mentioned in the manual this causes the uid and gid settings to be ignored.
Everything works fine when I access the partition normally. I'm able to change permissions, ownership and execute files, so that's great. However, it would be nice if apache (running as www-data) can also access the files on the partition, which it can't right now.
The line in fstab looks like this:
<UUID> <mount point> ntfs-3g x-gvfs-show,x-gvfs-name=Data,exec,hide_hid_files,hide_dot_files 0 0
To test the access for the apache user I've simply tried:
sudo -u www-data ls -all <absolute path to mount point>
Which returns:
ls: cannot access Data: Permission denied
I also tried to change the group on the mount point to the same group the www-data user is in (which is www-data), without effect.
Is there anything I overlook or can try? Any help would be greatly appreciated!
EDIT
Output of ntfs-3g.secaudit Data/Server/index.html
secaudit 1.4.0 : NTFS security data auditing
File Data/Server/index.html
Windows attrib : 0x20
Interpreted Unix owner 1000, group 33, mode 0666
No errors were found
Directory Data/Server/
Windows attrib : 0x30
Interpreted Unix owner 1000, group 33, mode 0750
Posix descriptor :
acccnt 3
defcnt 3
firstdef 3
mode : 0750
tagsset : 0x25
Posix ACL :
version 2
flags 0x00
ace 0 : access USR-O -1 perms 0007 rwx
ace 1 : access GRP-O -1 perms 0005 r-x
ace 2 : access OTHER -1 perms 0000 ---
ace 3 : default USR-O -1 perms 0007 rwx
ace 4 : default GRP-O -1 perms 0007 rwx
ace 5 : default OTHER -1 perms 0007 rwx
