What is a good twitter desktop client for Ubuntu 12.04?
I've used to use corebird for 14.04 and 14.10. But it's some how buggy and it's not available for Ubuntu 12.04
There are quite a few (though I have not tried all of them in 12.04):
To install this, run the following code in the terminal:
sudo apt-get install gwibber
although a post Install latest Gwibber (friends-app) in Ubuntu 12.04? says that the package is broken (I have not tested this)
Polly - supports in-line images
To install this, run the following code in the terminal (more info is available at How do I install Polly?):
sudo add-apt-repository ppa:conscioususer/polly-daily
sudo apt-get update
sudo apt-get install polly
Turpial - supports multi-column layout and multi-account
To install this run the following codes in the terminal:
sudo apt-get install turpial
TTYtter CLI, but not currently under development I guess
To use this, first download the perl script from here to a location on your computer from where you want to run it. Then make it executable with:
chmod +x <path/to/script-file>
and run it with:
./ttytter
Birdie - Reported to be buggy in 12.04 but worth a try
To install this, run the following commands in the terminal:
sudo add-apt-repository ppa:birdie-team/stable
sudo apt-get update
sudo apt-get install birdie
