How do you add new files, eg custom init script into .deb package that you're building?
Asked
Active
Viewed 3,177 times
Flint, the simplest way is to add the file to debian/install, or debian/binary-package-name.install. The format of the file is
source/relative/to/source/root destination/relative/to/system/root
So if you want to put contrib/scripts/admintool into /usr/bin/foo-admintool You'd do:
contrib/scripts/admintool usr/bin/foo-admintool
dh_install, which reads these, is fairly smart and will try to set permissions to the right values.
Specifically for init scripts, there is dh_installinit. You should probably read man dh_installinit to understand it fully, but basically if you have
debian/package-name.foo.init
It will be installed as /etc/init.d/foo and setup to start on installation/boot.
Subsequently, if you write an upstart job
debian/package-name.foo.upstart
Will be put in as /etc/init/foo.conf
And a symlink will be created as /etc/init.d/foo that points to an upstart wrapper for sysv compatibility.
SpamapS
- 20,110
