I would like a shell script to execute each time I insert a USB modem.
How would I do this?
You can accomplish this with some udev rules, as @Rinzwind suggested.
First, save your script to somewhere accessible by other users. For example, you could save it as /usr/local/bin/script.sh.
Now, make the script accessible by others.
sudo chmod 555 /usr/local/bin/script.sh
Now, plug in your USB modem and then run lsusb. Below is an example output:
$ lsusb
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 002: ID 0fcf:1008 Dynastream Innovations, Inc. Mini stick Suunto
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Find the line with your modem's name at the end. Now, find the portion near the middle in the format ID XXXX:####. The XXXX and #### portions will be, the Vendor ID and Device ID respectively.
For this example for the third line, which reads … ID 0fcf:1008 Dynastream …, the vendor ID is 0fcf and the Device ID is 1008. Your device will have different values for these IDs.
Now, we will use these IDs to create a rule for udev.
Now, create a rule for this device with udev.
Make a rules file with
sudo nano /etc/udev/rules.d/90-local.rules
Add the following line:
ACTION=="add", SUBSYSTEM=="usb", ATTRS{vendor}=="0xXXXX", ATTRS{device}=="0x####", RUN+="/usr/local/bin/script.sh"
Replace XXXX with the vendor id from earlier, and replace #### with the product id from earlier.
Now, force udev to reload it's rules (alternatively you could skip this step and reboot)
udevadm control --reload-rules
sudo service udev restart
And you're done!
Sources: Similar question on SU concerning udev rules, Creating udev Rules
