im having problem updating my ubuntu 12.04 (64 bit)
ran below command
apt-get update && apt-get upgrade
resulted to:
Setting up libglib2.0-bin (2.32.4-0ubuntu1) ...
rmdir: failed to remove `/etc/etc/': Not a directory
dpkg: error processing libglib2.0-bin (--configure):
subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of lightdm:
lightdm depends on libglib2.0-bin; however:
Package libglib2.0-bin is not configured yet.
dpkg: error processing lightdm (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of unity:
unity depends on libglib2.0-bin; however:
dpkg: error processing unity (--configure):
No apport report written because the error message indicates its a followup error from a previous failure.        No apport report written because the error message indicates its a followup error from a previous failure.
 libglib2.0-bin
 lightdm
 unity
Try the following:
sudo apt-get remove --purge libglib2.0-bin
sudo apt-get update
sudo apt-get install libglib2.0-bin
sudo apt-get -f install
sudo apt-get dist-upgrade
Note from comments: there appears to be a bug as described here There shouldn't be an /etc/etc/ folder path. I don't know how you got it. Try to reinstall dpkg with sudo apt-get install --reinstall dpkg if that fails try sudo apt-get remove --purge dpkg and install it again with sudo apt-get install dpkg.
Elder Geek
  • 36,752
JoKeR
  • 7,062
