Is it possible to set the order in which extensions/indicators appear in the top panel in gnome 3 as they seem to change position every time I login and I want to set a specific order.
Asked
Active
Viewed 5,837 times
TL;DR The way is a little bit tricky:
You can reload and so influence the order the extensions.
Use this command and replace <Extension_UUID> with the UUID of the extension, don't use the ID:
gdbus call --session --dest org.gnome.Shell --object-path /org/gnome/Shell --method <Extension_UUID>
But I have found that sometimes the extension must be reloaded twice to achieve an effect.
Example:
My system wide extensions:
% ls -og /usr/share/gnome-shell/extensions
total 4
drwxr-xr-x 2 4096 Mär 31 15:15 GPaste@gnome-shell-extensions.gnome.org
My per user extensions:
% ls -og ~/.local/share/gnome-shell/extensions/
total 16
drwxrwxr-x 3 4096 Mär 26 08:01 drive-menu@gnome-shell-extensions.gcampax.github.com
drwxrwxr-x 3 4096 Mär 26 08:02 laine@knasher.gmail.com
drwxrwxr-x 4 4096 Mär 26 07:56 user-theme@gnome-shell-extensions.gcampax.github.com
drwxrwxr-x 3 4096 Mär 26 07:57 web_search_dialog@awamper.gmail.com
The extension ID should be the folder name, eg. drive-menu@gnome-shell-extensions.gcampax.github.com.
To be sure, I would pick up the UUID from the metadata file:
% less ~/.local/share/gnome-shell/extensions/drive-menu@gnome-shell-extensions.gcampax.github.com/metadata.json
"_generated": "Generated by SweetTooth, do not edit",
"description": "A status menu for accessing and unmounting removable devices.",
"extension-id": "drive-menu",
"gettext-domain": "gnome-shell-extensions",
"name": "Removable Drive Menu",
"settings-schema": "org.gnome.shell.extensions.drive-menu",
"shell-version": [
"3.16"
"url": "http://git.gnome.org/gnome-shell-extensions",
"uuid": "drive-menu@gnome-shell-extensions.gcampax.github.com",
"version": 28
Therefore this is the command to reload the extension
gdbus call --session --dest org.gnome.Shell --object-path /org/gnome/Shell --method org.gnome.Shell.Extensions.ReloadExtension "drive-menu@gnome-shell-extensions.gcampax.github.com"
The UUID can be determined reliably with the following commands:
Install a JSON parser:
sudo apt-get install jq
Determine the UUID with:
jq '.uuid' ~/.local/share/gnome-shell/extensions/<shell_extension_path>/metadata.json
Example:
% jq '.uuid' ~/.local/share/gnome-shell/extensions/drive-menu@gnome-shell-extensions.gcampax.github.com/metadata.json
Or all in one:
gdbus call --session --dest org.gnome.Shell --object-path /org/gnome/Shell --method org.gnome.Shell.Extensions.ReloadExtension $(jq '.uuid' ~/.local/share/gnome-shell/extensions/drive-menu@gnome-shell-extensions.gcampax.github.com/metadata.json)
