I've been trying to get jslint to run on my system but have failed. I went with the npm route and simply ran sudo npm install -g jslint
I'm using the nodejs package not node-legacy. I also made a symbolic link to: sudo ln -s /usr/bin/nodejs /usr/bin/node
because it wasn't finding node. So JSlint insalled but when i run jslint in the terminal I get this:
module.js:340
throw err;
Error: Cannot find module 'readable-stream'
at Function.Module._resolveFilename (module.js:338:15)
at Function.Module._load (module.js:280:25)
at Module.require (module.js:364:17)
at require (module.js:380:17)
at Object.<anonymous> (/home/felipe/.npm/j slint/0.9.0/package/lib/stream.js:1:80)
at Module._compile (module.js:456:26)
at Object.Module._extensions..js (module.js:474:10)
at Module.load (module.js:356:32)
at Function.Module._load (module.js:312:12)
at Module.require (module.js:364:17)`
so I ran sudo npm install -g readable-stream , to verify I looked in /home/me/.npm/ and there is indeed a readable-stream folder. Version 1.0.33 to be exact. And I still get the same error. So I'm out of ideas. I would appreciate any help on trying to resolve this issue.
I was trying to get JSLint to work on sublime text 3 by using package install --> JSLint and I also tried SublimeLinter but I've failled with all 3. I could always install brackets which comes with JSLint by default but I'd like to get it to work in the terminal as well and possibly st3
