This is my first time using Ubuntu to run a C-File with a codeBlocks
  1. I tried save as a File "file1" without extension file.
    Permission Denied
  2. I tried chmod u+x file1
    Wrong something but builded success
  3. I tried give "file1.c"
    File not found
BeGood
  • 539
First of all, Any C program is saved with .c Extension. And C++ program is saved with .cpp extension.
Now coming to compilation,
  1. If you want to compile it using Terminal, Open the terminal (Press CTRL + ALT + T).
  2. Go to the directory where the file is saved. (You can use cd command to change directory).
  3. After reaching the directory , type gcc file1.c.
  4. If there are no errors, then you can run the output by typing ./a.out.
-1
Make sure you're the owner of the files. If you're not, you can run:
sudo chown usrname:username /path/to/your/file
Also make sure it's executable:
chmod +x /path/to/your/file
Bilal
  • 3,747
