15
Im using Ubuntu 15.04 and OpenJDK 7, trying to run Minecraft. This is what I get.
EDIT: Minecraft is working now when I use sudo java -jar Minecraft.jar but doesn't work without super user, how would I fix this! The reason i can't run it as super user all the time is because i want to be able to run by double-clicking it on desktop.
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 4/10)
Exception: javax.net.ssl.SSLException: java.lang.RuntimeException: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
When running it. I have tried using OpenJDK 8 and it did this as well, also I have tried Oracle's java 8.
Minecraft worked fine on my old 14.04 laptop using OpenJDK 7.
EDIT 2: Now after getting SSL exception, it starts the launcher and says Play Offline, so I went to "launcher log" tab and i get this (Sorry Its not in code format because I cant get that to work please edit that!):
[16:46:39 INFO]: Minecraft Launcher 1.6.11 (through bootstrap 5) started on linux...
[16:46:39 INFO]: Current time is May 25, 2015 4:46:39 PM
[16:46:39 INFO]: System.getProperty('os.name') == 'Linux'
[16:46:39 INFO]: System.getProperty('os.version') == '3.19.0-18-lowlatency'
[16:46:39 INFO]: System.getProperty('os.arch') == 'amd64'
[16:46:39 INFO]: System.getProperty('java.version') == '1.8.0_45-internal'
[16:46:39 INFO]: System.getProperty('java.vendor') == 'Oracle Corporation'
[16:46:39 INFO]: System.getProperty('sun.arch.data.model') == '64'
[16:46:39 INFO]: proxy == DIRECT
[16:46:39 INFO]: Refreshing local version list...
[16:46:39 INFO]: Refreshing remote version list...
[16:46:39 ERROR]: Unexpected exception refreshing version list
    at sun.security.ssl.Alerts.getSSLException(Alerts.java:208) ~[?:1.8.0_45-internal]
    at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1937) ~[?:1.8.0_45-internal]
    at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1894) ~[?:1.8.0_45-internal]
    at sun.security.ssl.SSLSocketImpl.handleException(SSLSocketImpl.java:1877) ~[?:1.8.0_45-internal]
    at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1398) ~[?:1.8.0_45-internal]
    at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1375) ~[?:1.8.0_45-internal]
    at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:563) ~[?:1.8.0_45-internal]
    at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:185) ~[?:1.8.0_45-internal]
    at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1512) ~[?:1.8.0_45-internal]
    at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1440) ~[?:1.8.0_45-internal]
    at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(HttpsURLConnectionImpl.java:254) ~[?:1.8.0_45-internal]
    at com.mojang.launcher.Http.performGet(Http.java:54) ~[launcher.jar:1.6.11]
    at net.minecraft.launcher.updater.RemoteVersionList.getContent(RemoteVersionList.java:27) ~[launcher.jar:1.6.11]
    at net.minecraft.launcher.updater.VersionList.refreshVersions(VersionList.java:85) ~[launcher.jar:1.6.11]
    at net.minecraft.launcher.updater.MinecraftVersionManager.refreshVersions(MinecraftVersionManager.java:60) ~[launcher.jar:1.6.11]
    at net.minecraft.launcher.Launcher$2.run(Launcher.java:132) [launcher.jar:1.6.11]
    at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_45-internal]
    at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_45-internal]
    at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:1.8.0_45-internal]
    at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:1.8.0_45-internal]
    at java.lang.Thread.run(Thread.java:745) [?:1.8.0_45-internal]
Caused by: java.lang.RuntimeException: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
    at sun.security.validator.PKIXValidator.<init>(PKIXValidator.java:90) ~[?:1.8.0_45-internal]
    at sun.security.validator.Validator.getInstance(Validator.java:179) ~[?:1.8.0_45-internal]
    at sun.security.ssl.X509TrustManagerImpl.getValidator(X509TrustManagerImpl.java:312) ~[?:1.8.0_45-internal]
    at sun.security.ssl.X509TrustManagerImpl.checkTrustedInit(X509TrustManagerImpl.java:171) ~[?:1.8.0_45-internal]
    at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:184) ~[?:1.8.0_45-internal]
    at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:124) ~[?:1.8.0_45-internal]
    at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1460) ~[?:1.8.0_45-internal]
    at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:212) ~[?:1.8.0_45-internal]
    at sun.security.ssl.Handshaker.processLoop(Handshaker.java:979) ~[?:1.8.0_45-internal]
    at sun.security.ssl.Handshaker.process_record(Handshaker.java:914) ~[?:1.8.0_45-internal]
    at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1050) ~[?:1.8.0_45-internal]
    at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1363) ~[?:1.8.0_45-internal]
    at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1391) ~[?:1.8.0_45-internal]
    ... 16 more
Caused by: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
    at java.security.cert.PKIXParameters.setTrustAnchors(PKIXParameters.java:200) ~[?:1.8.0_45-internal]
    at java.security.cert.PKIXParameters.<init>(PKIXParameters.java:120) ~[?:1.8.0_45-internal]
    at java.security.cert.PKIXBuilderParameters.<init>(PKIXBuilderParameters.java:104) ~[?:1.8.0_45-internal]
    at sun.security.validator.PKIXValidator.<init>(PKIXValidator.java:88) ~[?:1.8.0_45-internal]
    ... 16 more
[16:46:40 INFO]: Loaded 2 profile(s); selected 'AsherMaster'
[16:46:40 INFO]: Refreshing auth...
[16:46:40 INFO]: Logging in with access token
[16:46:40 ERROR]: Exception whilst logging into profile
com.mojang.authlib.exceptions.AuthenticationUnavailableException: Cannot contact authentication server
    at com.mojang.authlib.yggdrasil.YggdrasilAuthenticationService.makeRequest(YggdrasilAuthenticationService.java:71) ~[launcher.jar:1.6.11]
    at com.mojang.authlib.yggdrasil.YggdrasilUserAuthentication.logInWithToken(YggdrasilUserAuthentication.java:132) ~[launcher.jar:1.6.11]
    at com.mojang.authlib.yggdrasil.YggdrasilUserAuthentication.logIn(YggdrasilUserAuthentication.java:55) ~[launcher.jar:1.6.11]
    at net.minecraft.launcher.Launcher.ensureLoggedIn(Launcher.java:214) [launcher.jar:1.6.11]
    at net.minecraft.launcher.Launcher$2.run(Launcher.java:168) [launcher.jar:1.6.11]
Caused by: javax.net.ssl.SSLException: java.lang.RuntimeException: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
    at sun.net.www.protocol.http.HttpURLConnection.getOutputStream0(HttpURLConnection.java:1282) ~[?:1.8.0_45-internal]
    at sun.net.www.protocol.http.HttpURLConnection.getOutputStream(HttpURLConnection.java:1257) ~[?:1.8.0_45-internal]
    at sun.net.www.protocol.https.HttpsURLConnectionImpl.getOutputStream(HttpsURLConnectionImpl.java:250) ~[?:1.8.0_45-internal]
    at com.mojang.authlib.HttpAuthenticationService.performPostRequest(HttpAuthenticationService.java:73) ~[launcher.jar:1.6.11]
    at com.mojang.authlib.yggdrasil.YggdrasilAuthenticationService.makeRequest(YggdrasilAuthenticationService.java:54) ~[launcher.jar:1.6.11]
    ... 9 more
    ... 9 more
    ... 9 more
Thomas Ward
  • 78,878
ashermaster
  • 239
Actually, a better answer is to enter the following at the command prompt.
sudo update-ca-certificates -f
amc
  • 7,292
Open a terminal and fire this command:
sudo apt-get install --reinstall ca-certificates-java
And make sure that the time setting of your system is correct.
Source
I quote:
Basically, Minecraft uses SSL to protect your login, but Java didn’t have the certificates needed to verify. The Minecraft launcher really should give a better error message, but this was really Ubuntu’s fault. You need the ca-certificates-java package installed, but on my Ubuntu install, it was broken. Try doing ls /etc/ssl/certs/java/cacerts. If it comes up missing, then you need copy it from a friend or a different Unix machine. You don’t want to copy security files from strangers…
A.B.
  • 92,125
I finally found a solution after none of the others worked for me. At the bottom of this bug report, I found this magical series of commands:
sudo dpkg --purge --force-depends ca-certificates-java
And then:
sudo apt-get install ca-certificates-java
This instantly solved the problem for me.
I just solved it! Here is how to fix all SSL errors in Minecraft.
  1. You need another Linux computer's "cacerts" file, so on another Linux PC run this command:
    readlink -f /usr/bin/java | sed "s:bin/java::"
    and go to that path (Something like /usr/lib/jvm/java-8-openjdk-amd64/jre/).
  2. Open the "lib" folder, then open the "security" folder.
  3. Copy the "cacerts" file.
  4. Run the command again on your computer and go to that path:
    • If you are having trouble editing things, you need to open "Files" using sudo -H nautilus.
  5. Open "lib" and then "security" again.
  6. Replace the "cacerts" file with the file from the other PC.
If you can't find the "cacerts" file on another PC, check this path for it /etc/ssl/certs/java/ and you should see cacerts. I can't guarantee this working though.
wjandrea
  • 14,504
ashermaster
  • 239
