After the last software update on my Ubuntu 15.04 system, the wired network interface has stopped working. The eth0 interface is still configured and the ping to the DHCP assigned address works fine but any other ping to external IP do not work anymore.
When the PC boots it works just at the beginning but after few seconds, the eth0 is not able anymore to route any packet
Shall the following info not be enough, feel free to ask and I'dd provide more details
renato@UbuntuDesktop:~$ uname -a
Linux UbuntuDesktop 3.19.0-18-generic #18-Ubuntu SMP Tue May 19 18:31:35 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
What I've found suspicious is the fatal interrupt message within the log message as shown below
renato@UbuntuDesktop:~$ dmesg | grep eth0
[    0.602937] alx 0000:04:00.0 eth0: Qualcomm Atheros AR816x/AR817x Ethernet [4c:72:b9:80:98:63]
[   16.902801] alx 0000:04:00.0 eth0: NIC Up: 1 Gbps Full
[  450.877273] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[  451.034930] alx 0000:04:00.0 eth0: NIC Up: 1 Gbps Full
[  921.649932] alx 0000:04:00.0 eth0: fatal interrupt 0x400, resetting
[  921.652184] alx 0000:04:00.0 eth0: NIC Up: 1 Gbps Full
Below are listed the network interfaces
renato@UbuntuDesktop:~$ ifconfig -a
eth0      Link encap:Ethernet  HWaddr 4c:72:b9:80:98:63
      inet addr:10.0.0.8  Bcast:10.0.0.255  Mask:255.255.255.0
      inet6 addr: fe80::4e72:b9ff:fe80:9863/64 Scope:Link
      UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
      RX packets:8469 errors:6141 dropped:0 overruns:6141 frame:0
      TX packets:2390 errors:0 dropped:0 overruns:0 carrier:0
      collisions:0 txqueuelen:1000
      RX bytes:811556 (811.5 KB)  TX bytes:357041 (357.0 KB)
      Interrupt:17
lo        Link encap:Local Loopback
      inet addr:127.0.0.1  Mask:255.0.0.0
      inet6 addr: ::1/128 Scope:Host
      UP LOOPBACK RUNNING  MTU:65536  Metric:1
      RX packets:5919 errors:0 dropped:0 overruns:0 frame:0
      TX packets:5919 errors:0 dropped:0 overruns:0 carrier:0
      collisions:0 txqueuelen:0
      RX bytes:644195 (644.1 KB)  TX bytes:644195 (644.1 KB)
wlan0     Link encap:Ethernet  HWaddr a4:17:31:22:f3:21
      inet addr:10.0.0.19  Bcast:10.0.0.255  Mask:255.255.255.0
      inet6 addr: fe80::a617:31ff:fe22:f321/64 Scope:Link
      RX packets:16844 errors:0 dropped:0 overruns:0 frame:0
      TX packets:12404 errors:0 dropped:0 overruns:0 carrier:0
      RX bytes:15507666 (15.5 MB)  TX bytes:1774154 (1.7 MB)
How can I restore it?
After some research, I've found the root cause.
As reported here: https://bugs.archlinux.org/task/44315, the issue is due to the combination of the new linux kernel version with the Qualcomm ethernet driver
The following combination IS NOT WORKING
  • Linux kernel 3.19.0-18 (Ubuntu 15.04)
  • Ethernet driver alx 0000:04:00.0 eth0: Qualcomm Atheros AR816x/AR817x Ethernet
In the above post it has been suggested to either
  • Downgrade the Linux kernel to 3.18.6 or
  • Configure the eth0 interface with the MTU = 900
Before downgrading the Linux kernel, I've tried to enforce the MTU configuration on the eth0 interface but unfortunately it worked only for a little while and then it stopped working again. According to other users comments, this work-around should have fixed the issue but unfortunately not for me.
Finally I decided to downgrade the Linux kernel to 3.18.6-031806-generic and my wired interface is working fine again.
