I am using Genymotion version 2.3.1 in my Ubuntu machine. I am able to copy files from the host machine to Genymotion by a simple drag and drop method. But I am unable to copy Genymotion data to the host machine. I want to move data from Genymotion to the host machine. How I can transfer data?
Asked
Active
Viewed 3.7k times
17
Try this:
- Go to your VirtualBox VM settings Shared folder tab (open VirtualBox > select the Android/Genymotion virtual machine > Settings > Shared folders)
- Add a shared folder with the folder you want to share, and check the auto mount and permanent options
- Start your VM as usual from the Genymotion software
- Your shared folder is available in the
/mnt/shareddirectory (multiple shared folders are supported)
Source: Accessing files from Genymotion SD card | Stack Overflow
Zanna
- 72,312
Smile4ever
- 1,091
This feature is not supported with Android 10 (API 29) virtual devices. But You can connect your Android phone to Genymotion and copy your data.
