for some reason my machine has problems with suspension, specifically, it resumes as soon as it suspends. After some research I was able to solve this problem on 14.04 by using the following loop, as per this answer: https://askubuntu.com/a/268172
#!/bin/bash
case $1 in
    hibernate)
            echo "Going to suspend to disk!"
    suspend)
            echo "Fixing acpi settings."
            for usb in 'XHC' 'EHC1' 'EHC2';
            do
                    state=`cat /proc/acpi/wakeup | grep $usb | cut -f3 | cut -d' ' -f1 | tr -d '*'`
                    echo "device = $usb, state = $state"
                    if [ "$state" == "enabled" ]
                    then
                            echo $usb > /proc/acpi/wakeup
                    fi
            done
            echo "Suspending to RAM."
    thaw)
            echo "Suspend to disk is now over!"
    resume)
            echo "We are now resuming."
            echo "Somebody is callin me totally wrong."
esac
However with the new systemd this solution isnt working anymore, I managed to create and place the same script on /usr/lib/systemd/system-sleep/, however this doesnt work as it doesnt execute, here is the output of my journal:
may 22 22:59:43 waiobook systemd[1]: Starting Suspend...
may 22 22:59:43 waiobook systemd-sleep[1372]: Suspending system...
may 22 22:59:49 waiobook systemd-sleep[1372]: System resumed.
may 22 22:59:49 waiobook systemd[1]: Started Suspend.
may 22 20:09:03 waiobook systemd[1]: Starting Suspend...
may 22 20:09:03 waiobook systemd-sleep[2674]: Suspending system...
may 22 20:09:07 waiobook systemd-sleep[2674]: System resumed.
may 22 20:09:07 waiobook systemd[1]: Started Suspend.
So i'm guessing im doing something wrong with the script?
Any help is aprecciated.
The script parameters have changed as well as directory. $1 is "post" on resume/thaw, "pre" otherwise. $2 in both cases contains either "suspend", "hibernate", or "hybrid-sleep". Modifying your example:
#!/bin/bash
case $1 in
pre) case $2 in
    hibernate)
    hybrid-sleep)
            echo "Going to suspend to disk and ram!"
    suspend)
            do
                    then
                    fi
            done
    esac ;;
post)
        echo "We are now resuming from $2."
esac
Martin Thornton
  • 5,996
  • 32
  • 43
