Hi Team Of Ubuntu I Want To ask You . How To login With Root In Ubuntu 14.10
Sorry My English Is Bad
Type sudo su in the terminal. This will open a root session. Be very careful, as you can do very bad things with this.
If you want to run a program in a GUI as root, type "gksudo".
However, this thread may be of use to you. It is much more dangerous than simply using sudo. If you want to do it, you can. (Command is sudo passwd -u root [password])
