You can make a conditional to relaunch the script as root if it's launched as a normal user.
To shutdown the computer:
#!/bin/bash
if [[ $USER == "eka" ]]; then # If the script is ran as "eka" then...
sudo $0 # relaunch it as "root".
exit 0 # Once it finishes, exit gracefully.
elif [[ $USER != "root" ]]; then # If the user is not "eka" nor "root" then...
fi # End if.
shutdown -h +30;
read -p "Press any key to continue... " -n1 -s
Simplified version:
#!/bin/bash
[[ $USER == "eka" ]] && { sudo $0; exit 0; }
[[ $USER != "root" ]] && exit 0
shutdown -h +30;
Very simplified version (not recommended):
#!/bin/bash
sudo $0 # Relaunch script as root (even if it's already running as root)
shutdown -h +30; # Shutdown the computer in 30 seconds.
To suspend the computer:
#!/bin/bash
if [[ $USER == "eka" ]]; then # If the script is ran as "eka":
gnome-screensaver-command -a # Lock computer.
else # Else:
sudo -u eka gnome-screensaver-command -a # Once it finishes, exit gracefully.
fi # End if.
Simplified version:
#!/bin/bash
[[ $USER != "eka" ]] && { sudo -u eka gnome-screensaver-command -a; exit 0; }
Very simplified version:
#!/bin/bash
Note: $0 is a variable that holds the full path to the script.
