-1
I tried to install mysql server and mysql workbench with Ubuntu software center but It could not install them. Then I used command line to install mysql server and I run the following code repectivly:
sudo apt-get update && sudo apt-get upgrade
sudo apt-get install mysql server
But,I got the following error after the last command:
mysql-server : Depends: mysql-community-server (= 5.6.24-1ubuntu14.10)   but it is not going to be installed
How can I solve this problem? IS there any simple way to install mysql server and mysql workbench?
These are all mysql version on my computer:
`apt-cache search mysql|egrep '^mysql'
 mysql-client-5.5 - MySQL database client binaries
 mysql-client-core-5.5 - MySQL database core client binaries
 mysql-server-5.5 - MySQL database server binaries and system database    setup
 mysql-server-core-5.5 - MySQL database server binaries
 mysql-client-5.6 - MySQL database client binaries
 mysql-client-core-5.6 - MySQL database core client binaries
 mysql-common-5.6 - MySQL 5.6 specific common files, e.g. /etc/mysql/conf.d/my-5.6.cnf
 mysql-mmm-agent - Multi-Master Replication Manager for MySQL - agent daemon
 mysql-mmm-common - Multi-Master Replication Manager for MySQL - common files
 mysql-mmm-monitor - Multi-Master Replication Manager for MySQL - monitoring daemon
 mysql-mmm-tools - Multi-Master Replication Manager for MySQL - tools
 mysql-proxy - high availability, load balancing and query modification for mysql
 mysql-server-5.6 - MySQL database server binaries and system database setup
 mysql-server-core-5.6 - MySQL database server binaries
 mysql-source-5.5 - MySQL source
 mysql-source-5.6 - MySQL source
 mysql-testsuite-5.5 - MySQL testsuite
 mysql-testsuite-5.6 - MySQL 5.6 testsuite
 mysql-utilities - collection of scripts for managing MySQL servers
 mysql-workbench - MySQL Workbench - a visual database modeling, administration and queuing tool
 mysql-workbench-data - MySQL Workbench -- architecture independent data
 mysqltcl - interface to the MySQL database for the Tcl language
 mysqltuner - high-performance MySQL tuning script
 mysql-apt-config - Auto configuration for MySQL APT Repo.
 mysql-client - MySQL Client meta package depending on latest version
 mysql-common - MySQL Common
 mysql-community-bench - MySQL Bench
 mysql-community-client - MySQL Client
 mysql-community-server - MySQL Server
 mysql-community-source - MySQL source
 mysql-community-test - MySQL Test Run MTR - The MySQL testsuite
 mysql-server - MySQL Server meta package depending on latest version
 mysql-testsuite - MySQL Testsuite meta package depending on latest version
 mysql-workbench-community - MySQL Workbench
Try following command in a terminal--
sudo apt-get purge mysql-client-core-5.6
sudo apt-get install mysql-client-core-5.6
sudo apt-get install mysql-server
gman
  • 2,324
