I am using Ubuntu 14.04 with HWE stack (kernel 3.16) on a Dell Inspiron 15-5547, AMD Radeon HD R7 M265.
I've been trying to install the proprietary drivers fglrx drivers in order to be able to switch between my graphic cards. After some trial I found this this bug. Without, really thinking it thru, I followed the suggestion of comment 24 and run
sudo apt-get install xserver-xorg-core
The installation did not finish, but returned in
Extracting templates from packages: 100%
(Reading database ... 773072 files and directories currently installed.)
Preparing to unpack .../libgl1-mesa-dri_10.1.3-0ubuntu0.4_amd64.deb ...
Unpacking libgl1-mesa-dri:amd64 (10.1.3-0ubuntu0.4) ...
dpkg: error processing archive /var/cache/apt/archives/libgl1-mesa-dri_10.1.3-0ubuntu0.4_amd64.deb (--unpack):
trying to overwrite shared '/etc/drirc', which is different from other instances of package libgl1-mesa-dri:amd64
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Now, I want to revert that change. I tried sudo apt-get remove xserver-xorg-core, sudo apt-get -f install, sudo apt-get autoremove, sudo apt-get clean, sudo apt-get autoclean but what I get is:
bruni@bruni-Inspiron-5547:~$ sudo apt-get autoremove
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
libegl1-mesa-drivers : Depends: libgl1-mesa-dri
libgbm1 : Depends: libgl1-mesa-dri
libgl1-mesa-dri-lts-quantal : Depends: libgl1-mesa-dri
qtdeclarative5-qtquick2-plugin : Depends: libgl1-mesa-dri
xorg : Depends: xserver-xorg (>= 1:7.7+1ubuntu8.1) orN
xserver-xorg-renamed
xserver-xorg-lts-quantal : Depends: xserver-xorg
xserver-xorg-video-all-lts-utopic : Depends: xserver-xorg-video-ati-lts-topic but it is not installed
Depends: xserver-xorg-video-cirrus-lts-utopic but it is not installed
Depends: xserver-xorg-video-fbdev-lts-utopic but it is not installed
Depends: xserver-xorg-video-intel-lts-utopic but it is not installed
Depends: xserver-xorg-video-mga-lts-utopic but it is not installed
Depends: xserver-xorg-video-modesetting-lts-utopic but it is not installed
Depends: xserver-xorg-video-neomagic-lts-utopic but it is not installed
Depends: xserver-xorg-video-nouveau-lts-utopic but it is not installed
Depends: xserver-xorg-video-openchrome-lts-utopic but it is not installed
Depends: xserver-xorg-video-savage-lts-utopic but it is not installed
Depends: xserver-xorg-video-siliconmotion-lts-utopic but it is not installed
Depends: xserver-xorg-video-sisusb-lts-utopic but it is not installed
Depends: xserver-xorg-video-tdfx-lts-utopic but it is not installed
Depends: xserver-xorg-video-trident-lts-utopic but it is not installed
Depends: xserver-xorg-video-vesa-lts-utopic but it is not installed
Depends: xserver-xorg-video-vmware-lts-utopic but it is not installed
E: Unmet dependencies. Try using -f.
Any suggestions, how to clean up this mess?
sudo apt update or sudo apt-get update work normally.
Ign http://gr.archive.ubuntu.com trusty InRelease
Ign http://gr.archive.ubuntu.com trusty-security InRelease
Hit http://gr.archive.ubuntu.com trusty Release.gpg
Hit http://gr.archive.ubuntu.com trusty-security Release.gpg
Hit http://repo.steampowered.com precise InRelease
Hit http://gr.archive.ubuntu.com trusty/main Sources
Ign http://ppa.launchpad.net trusty InRelease
Hit http://gr.archive.ubuntu.com trusty/restricted Sources
Hit http://gr.archive.ubuntu.com trusty/universe Sources
Hit http://gr.archive.ubuntu.com trusty/multiverse Sources
Hit http://gr.archive.ubuntu.com trusty/main amd64 Packages
Hit http://gr.archive.ubuntu.com trusty/restricted amd64 Packages
Hit http://repository.spotify.com stable InRelease
Hit http://gr.archive.ubuntu.com trusty/universe amd64 Packages
Hit http://gr.archive.ubuntu.com trusty/multiverse amd64 Packages
Hit http://gr.archive.ubuntu.com trusty/main i386 Packages
Hit http://gr.archive.ubuntu.com trusty/restricted i386 Packages
Hit http://gr.archive.ubuntu.com trusty/universe i386 Packages
Hit http://repository.spotify.com stable/non-free amd64 Packages
Hit http://gr.archive.ubuntu.com trusty/multiverse i386 Packages
Hit http://repository.spotify.com stable/non-free i386 Packages
Hit http://ppa.launchpad.net trusty Release.gpg
Hit http://gr.archive.ubuntu.com trusty/main Translation-en
Hit http://gr.archive.ubuntu.com trusty/multiverse Translation-en
Hit http://gr.archive.ubuntu.com trusty/restricted Translation-en
Hit http://gr.archive.ubuntu.com trusty/universe Translation-en
Hit http://gr.archive.ubuntu.com trusty-security/main Sources
Hit http://gr.archive.ubuntu.com trusty-security/restricted Sources
Hit http://gr.archive.ubuntu.com trusty-security/universe Sources
Hit http://gr.archive.ubuntu.com trusty-security/multiverse Sources
Hit http://gr.archive.ubuntu.com trusty-security/main amd64 Packages
Hit http://gr.archive.ubuntu.com trusty-security/restricted amd64 Packages
Hit http://gr.archive.ubuntu.com trusty-security/universe amd64 Packages
Hit http://gr.archive.ubuntu.com trusty-security/multiverse amd64 Packages
Hit http://gr.archive.ubuntu.com trusty-security/main i386 Packages
Hit http://gr.archive.ubuntu.com trusty-security/restricted i386 Packages
Hit http://gr.archive.ubuntu.com trusty-security/universe i386 Packages
Hit http://repo.steampowered.com precise/steam Sources
Hit http://gr.archive.ubuntu.com trusty-security/multiverse i386 Packages
Hit http://gr.archive.ubuntu.com trusty-security/main Translation-en
Hit http://gr.archive.ubuntu.com trusty-security/multiverse Translation-en
Hit http://gr.archive.ubuntu.com trusty-security/restricted Translation-en
Hit http://gr.archive.ubuntu.com trusty-security/universe Translation-en
Hit http://ppa.launchpad.net trusty/main amd64 Packages
Hit http://ppa.launchpad.net trusty/main i386 Packages
Ign http://gr.archive.ubuntu.com trusty/main Translation-en_US
Ign http://gr.archive.ubuntu.com trusty/multiverse Translation-en_US
Ign http://gr.archive.ubuntu.com trusty/restricted Translation-en_US
Ign http://repository.spotify.com stable/non-free Translation-en_US
Ign http://gr.archive.ubuntu.com trusty/universe Translation-en_US
Hit http://repo.steampowered.com precise/steam amd64 Packages
Hit http://ppa.launchpad.net trusty/main Translation-en
Hit http://repo.steampowered.com precise/steam i386 Packages
Ign http://ppa.launchpad.net trusty/main Translation-en_US
Ign http://repo.steampowered.com precise/steam Translation-en_US
ls /etc/apt/sources.list.d However note that these are mostly disabled and should not be the problem.
ian-berke-ppa-drawers-trusty.list libreoffice-ppa-trusty.list spotify.list.save ultradvorka-ppa-trusty.list vikoadi-ppa-trusty.list
ian-berke-ppa-drawers-trusty.list.save spotify.list steam.list ultradvorka-ppa-trusty.list.save vikoadi-ppa-trusty.list.save
