shakil@shakil-Aspire-5733Z:~$ sudo apt-get -f install
[sudo] password for shakil:
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following extra packages will be installed:
linux-tools-common
The following NEW packages will be installed:
linux-tools-common
0 upgraded, 1 newly installed, 0 to remove and 6 not upgraded.
3 not fully installed or removed.
Need to get 0 B/88.0 kB of archives.
After this operation, 312 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 303158 files and directories currently installed.)
Preparing to unpack .../linux-tools-common_3.13.0-53.89_all.deb ...
Unpacking linux-tools-common (3.13.0-53.89) ...
dpkg: error processing archive /var/cache/apt/archives/linux-tools-common_3.13.0-53.89_all.deb (--unpack):
trying to overwrite '/usr/bin/perf', which is also in package linux-lts-vivid-tools-common 3.19.0-18.18~14.04.1
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
I have already tried:
sudo apt-get autoclean
sudo apt-get clean
sudo apt-get autoremove -f
sudo apt-get install -f
Please, can anyone help me?
