I'm installing Landscape with the Landscape OpenStack Autopilot:
  • Bootstrapping Juju took 233 sec
  • Preparing Landscape: 10 sec
  • Deploying Landscape has so far used 2620 sec (43 minutes, 40 seconds).
This is a very long time. Is it normal?
It just got to 3000 and gave an error:
From installer log:
File "/usr/share/openstack/cloudinstall/multi_install.py", line 771, in run_deployer
    raise Exception("Error deploying Landscape.")
Exception: Error deploying Landscape. )
A bit from the log :
  Service 'rabbitmq-server' does not need any more units added.\n2015-05-21 13:39:58 [DEBUG] deployer.import: Waiting for units before adding relations\n2015-05-21 13:43:32 [DEBUG] deployer.env:  Delta machine: 0/lxc/0 change:pending\n2015-05-21 13:43:52 [DEBUG] deployer.env:  Delta machine: 0/lxc/1 change:pending\n2015-05-21 13:44:12 [DEBUG] deployer.env:  Delta machine: 0/lxc/2 change:pending\n2015-05-21 13:44:32 [DEBUG] deployer.env:  Delta machine: 0/lxc/3 change:pending\n2015-05-21 13:44:52 [DEBUG] deployer.env:  Delta machine: 0/lxc/4 change:pending\n2015-05-21 13:45:12 [DEBUG] deployer.env:  Delta machine: 0/lxc/5 change:pending\n2015-05-21 14:29:30 [DEBUG] deployer.env: Connecting to environment...\n2015-05-21 14:29:32 [DEBUG] deployer.env: Connected to environment\n2015-05-21 14:29:32 [ERROR] deployer.import: Reached deployment timeout.. exiting\n2015-05-21 14:29:32 [INFO] deployer.cli: Deployment stopped. run time: 3015.07\n", 'status': 1}
[DEBUG ⢠05-21 14:29:32] ⢠cloudinstall.utils ⢠(utils.py, global_exchandler, 63)]
   Traceback (most recent call last):
  File "/usr/share/openstack/cloudinstall/utils.py", line 78, in run
    super().run()
  File "/usr/lib/python3.4/threading.py", line 868, in run
    self._target(*self._args, **self._kwargs)
  File "/usr/share/openstack/cloudinstall/machinewait.py", line 127, in do_continue
    self.installer.do_install()
  File "/usr/share/openstack/cloudinstall/multi_install.py", line 177, in do_install
    self.loop).run()
  File "/usr/share/openstack/cloudinstall/multi_install.py", line 708, in run
    self.deploy_landscape()
  File "/usr/share/openstack/cloudinstall/multi_install.py", line 731, in deploy_landscape
    self.run_deployer()
0xF2
  • 3,155
Ludwig
  • 41
Looks like the MAAS nodes never left the "pending" state. Can you select a node in MAAS and click "start", and see if it reaches the "Deployed" state?
I suggest to configure juju to use MAAS (https://jujucharms.com/docs/stable/config-maas) and then try to bootstrap and deploy the simple ubuntu charm to all nodes. This is a good pre-flight check.
Once you have the ~/.juju/environments.yaml file configured as per instructions from the link above, it's a simple matter of:
juju bootstrap
juju deploy ubuntu -n N
Where N is the number of nodes you have in MAAS minus 1 (which was used for bootstrapping).
