I have weird issue with ubuntu 14.04. When I trying update my system or install any software I have an error
$ sudo apt-get install 4digits
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
    4digits : Depends: python-glade2 but it is not going to be installed
    linux-tools-3.13.0-53 : Depends: linux-tools-common but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution)
So when I try start "sudo apt-get -f install" I have error again
Preparing to unpack .../linux-tools-common_3.13.0-53.89_all.deb ...
Unpacking linux-tools-common (3.13.0-53.89) ...
dpkg: error processing archive /var/cache/apt/archives/linux-tools-common_3.13.0-53.89_all.deb (--unpack):
    trying to overwrite '/usr/bin/perf', which is also in package linux-   lts-vivid-tools-common 3.19.0-18.18~14.04.1
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Thomas Ward
  • 78,878
Denis
  • 121
This bug is confirmed. As packages require vivid tools, upgadring to 15.04 may be a workaround.
apex39
  • 186
Try to repair your package management via
sudo apt-get purge linux-tools-3.13.0-53 linux-tools-common
Eventually remove the other app too
sudo apt-get purge 4digits
linrunner
  • 1,525
