16
My problem is after postgresql installed try to configure postgresql database it's show error message like below:
dineshlap@ss-laptop:~$ sudo -u postgres psql postgres
psql: could not connect to server: No such file or directory
    Is the server running locally and accepting
    connections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432"?
and i tried lot of solutions from internet. but, nothing worked for me! :(
if you know the solution for this problem please, answer this post!
Note : I'm using ubuntu 14.04 (64 bit) and postgresql 9.3
Dinesh
  • 281
5 Answers5
28
Just try to restart
sudo /etc/init.d/postgresql restart
this worked for me :)
Talal
  • 899
Ubuntu16.04 and 9.3
sudo systemctl restart postgresql-9.3.service
Maybe you find out service before restarting server
service --status-all
I had the same problem. after running
systemctl status postgresql@9.6-main.service
It showed the following error
data directory "/var/lib/postgresql/9.6/main" has group or world access
SOLUTION
so I ran:
sudo chmod 0700 /var/lib/postgresql/9.6/main
Then I restarted:
sudo systemctl restart postgresql@9.6-main.service
running sudo systemctl restart postgresql@9.6-main.service showed my service active and running!
Try this one sir,
Edited your pg_hba.conf and add your host address :
local    all    postgres                     peer
host     all    all         127.0.0.1/24     md5
and also edited your postgres.confadd your queue with :
listen_addresses = " * "
and then restart your service :
sudo service postgresql restart
see your log output said what the miracled:
sudo tail -f /var/log/postgresql/postgresql-9.6-main.log
Hope this helps sir.
In some case you may have permission issue. I create a shell script like this:
#!/bin/bash
chown -R $User:$User /var/run/postgresql
replace $User with your username, and execute the file (assuming the file name is postgresql.sh):
sudo ./postgresrun.sh
