I am using opencv 3 on ubunut 12.04 and while displaying an image the error message asks me to build the library with libgtk2.0-dev. I tried sudo apt-get install libgtk2.0-dev but I get the following error.
teraflops@teraflops-Inspiron-3542:~$ sudo apt-get install libgtk2.0-devReading package lists... Done
Building dependency tree
 libgtk2.0-dev : Depends: libpango1.0-dev (>= 1.20) but it is not going to be installed
                 Depends: libcairo2-dev (>= 1.6.4-6.1) but it is not going to be installed
I have almost tried all the online solutions like here 1 and here 2 with no results. Please suggest me any means to solve the problem. I have tried installing the libpango1-dev and libcairo2-dev separately but both have broken dependencies leading to libfontconfig1-dev. Trying to install the later gives
teraflops@teraflops-Inspiron-3542:~$ sudo apt-get install libfontconfig1-dev
 libfontconfig1-dev : Depends: libfontconfig1 (= 2.8.0-3ubuntu9.1) but 2.10.1-0ubuntu3 is to be installed
Any kind of suggestion/solution is most welcome
7 Answers7
Try installing all of them at the same time, like this:
sudo apt-get install libgtk2.0-dev libpango1-dev libcairo2-dev libfontconfig1-dev
ashermaster
  • 239
Sometimes the package dependencies are related to packages out of x86_64 architecture. Try these following steps:
  1. sudo dpkg --add-architecture i386
  2. sudo apt-get update
  3. sudo apt-get install libgtk2.0-dev
I hope to help you.
That line from the output you received (when trying to install libgtk2.0-dev) seems to indicate you need to fix broken and missing packages.
Try this:
sudo apt-get update && sudo apt-get upgrade --fix-missing --fix-broken
Then, assuming that was successful, you should be able to run the install command for libgtk2.0-dev without any problems
If it still doesn't work, try looking for what packages are being held back:
dpkg --get-selections | grep hold
If that command gives you any output (should be package names of whatever packages are being held) try this:
sudo apt-get install <packagename>
Then try to install libgtk2.0-dev again.
If it still fails, perhaps consider doing a dist-upgrade
sudo apt-get dist-upgrade
I hope this helps!
mason81
  • 215
I ran into this issue on 16.04 and the reason (for me at least) was that libcairo2-dev required on a specific version of libcairo-gobject2 and I had a newer one:
 libcairo2-dev : Depends: libcairo-gobject2 (= 1.14.6-1) but 1.15.2-0intel1 is to be installed
So the fix was:
sudo apt-get install libcairo-gobject2=1.14.6-1
Which then allowed me to install libgtk2.0-dev
The real proper fix is for the maintainers of libcairo2-dev/libcairo-gobject2 to properly fix their dependency is that one can use later version of libcairo2-gobject2.
AnthonyWC
  • 224
Test this:
Download this files to 32 bits:
http://mirrors.kernel.org/ubuntu/pool/main/g/gtk+2.0/libgtk2.0-dev_2.24.10-0ubuntu6_i386.deb
http://mirrors.kernel.org/ubuntu/pool/main/g/gtk+2.0/gir1.2-gtk-2.0_2.24.10-0ubuntu6_i386.deb
http://mirrors.kernel.org/ubuntu/pool/main/a/atk1.0/libatk1.0-dev_2.4.0-0ubuntu1_i386.deb
http://mirrors.kernel.org/ubuntu/pool/main/c/cairo/libcairo2-dev_1.10.2-6.1ubuntu2_i386.deb
http://mirrors.kernel.org/ubuntu/pool/main/g/gdk-pixbuf/libgdk-pixbuf2.0-dev_2.26.1-1_i386.deb
http://mirrors.kernel.org/ubuntu/pool/main/g/glib2.0/libglib2.0-dev_2.32.1-0ubuntu2_i386.deb
http://mirrors.kernel.org/ubuntu/pool/main/g/gtk+2.0/libgtk2.0-0_2.24.10-0ubuntu6_i386.deb
http://mirrors.kernel.org/ubuntu/pool/main/g/gtk+2.0/libgtk2.0-common_2.24.10-0ubuntu6_all.deb
http://mirrors.kernel.org/ubuntu/pool/main/p/pango1.0/libpango1.0-dev_1.30.0-0ubuntu2_i386.deb
http://mirrors.kernel.org/ubuntu/pool/main/libx/libxcomposite/libxcomposite-dev_0.4.3-2build1_i386.deb
http://mirrors.kernel.org/ubuntu/pool/main/libx/libxdamage/libxdamage-dev_1.1.3-2build1_i386.deb
http://mirrors.kernel.org/ubuntu/pool/main/p/pkg-config/pkg-config_0.26-1ubuntu1_i386.deb
Or download this files to 64 bit:
http://mirrors.kernel.org/ubuntu/pool/main/g/gtk+2.0/libgtk2.0-dev_2.24.10-0ubuntu6_amd64.deb
http://mirrors.kernel.org/ubuntu/pool/main/g/gtk+2.0/gir1.2-gtk-2.0_2.24.10-0ubuntu6_amd64.deb
http://mirrors.kernel.org/ubuntu/pool/main/a/atk1.0/libatk1.0-dev_2.4.0-0ubuntu1_amd64.deb
http://mirrors.kernel.org/ubuntu/pool/main/c/cairo/libcairo2-dev_1.10.2-6.1ubuntu2_amd64.deb
http://mirrors.kernel.org/ubuntu/pool/main/g/gdk-pixbuf/libgdk-pixbuf2.0-dev_2.26.1-1_amd64.deb
http://mirrors.kernel.org/ubuntu/pool/main/g/glib2.0/libglib2.0-dev_2.32.1-0ubuntu2_amd64.deb
http://mirrors.kernel.org/ubuntu/pool/main/g/gtk+2.0/libgtk2.0-0_2.24.10-0ubuntu6_amd64.deb
http://mirrors.kernel.org/ubuntu/pool/main/p/pango1.0/libpango1.0-dev_1.30.0-0ubuntu2_amd64.deb
http://mirrors.kernel.org/ubuntu/pool/main/libx/libxcomposite/libxcomposite-dev_0.4.3-2build1_amd64.deb
http://mirrors.kernel.org/ubuntu/pool/main/libx/libxdamage/libxdamage-dev_1.1.3-2build1_amd64.deb
http://mirrors.kernel.org/ubuntu/pool/main/p/pkg-config/pkg-config_0.26-1ubuntu1_amd64.deb
Install them with the command:
sudo dpkg --force-all -i *.deb
Executed in the download directory
kyodake
  • 17,808
Pretty simple issue -
You have libfontconfig1 2.10.1-0ubuntu3 from 12.10 installed but are on 12.04. So you'd need to replace that package with the 12.04 version & any other 12.10 package(s) you have installed that could cause conflicts. So good luck there...
apt-cache policy libfontconfig1 & or apt-cache madison libfontconfig1 should show this clearly
doug
  • 17,212
I had the same issue trying to install Wireshark 1.7.0 on my Ubuntu 12.04 - wireshark requires libgtk2.0-dev.
Everything is stuck because of the package libfontconfig1-dev:
  1. Add the precise-updates deb server in your /etc/apt/sources.list . For France:
deb http://fr.archive.ubuntu.com/ubuntu/ precise-updates main restricted
  1. Refresh aptitude:
apt-get update
  1. Now you can install the broken package
  1. Put all problematic packages on the same command line. Here:
apt-get install libgtk2.0-dev libpango1.0-dev libcairo2-dev
kos
  • 41,268
