I have a lenovo x230t and have recently begun to retry with getting my screen rotation to work properly. I've been using the following: https://github.com/martin-ueding/thinkpad-scripts. But calling xrandr --output display --rotate inverted causes the display to go black. However calling --rotate left/right/normal all work properly. The display shows that it has the option for inverted, but obviously is not working as intended and I'm not sure how to get it to work.
Asked
Active
Viewed 3,738 times
Temporal fix
xrandr -o normal
Constant fix
To file
/usr/share/X11/xorg.conf.d/10-quirks.conf
add lines
Section "Monitor"
Option "Rotate" "normal"
EndSection
It fixes problem on
Lenovo-Yoga710-14ISK
Ubuntu 20.04 LTS
GNOME Shell 3.36.1
More info:
- https://wiki.archlinux.org/index.php/Xrandr
- https://xorg-team.pages.debian.net/xorg/howto/use-xrandr.html
- https://unix.stackexchange.com/questions/103460/how-to-change-gnome-default-screen-rotation
- http://manpages.ubuntu.com/manpages/bionic/man5/xorg.conf.5.html
- Where is the X.org config file? How do I configure X there?
- https://www.x.org/releases/current/doc/man/man5/xorg.conf.5.xhtml#heading12
Daniel
- 397
It's a current bug in linux kernel
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1446979
The bug happens when switching between inverted and normal mode. A temporary solution is to rotate by 90° steps as follow
xrandr -o left && xrandr -o inverted
This worked for me on dell inspiron 13. Hope it will work for you
