11
After upgrade to 15.04 my ubuntu loads really slowly, slower than Windows 8 on the same machine, which insults me.
I turned off splash screen, and when I boot the system I get this:
A start job is running for dev-hdb2.device
and It stays that way for 1:30 minute, with a time counter next to it set exactly to 1:30.
Also when I reboot I get this message:
A stop job is running for Session c2 of user MrMino
same here - it stays that way for 1:30
Output of dmesg: http://pastebin.com/yzbFQG05
Unfortunately bootchart isn't working for some reason not known to me now, so I can't post logs from it.
How to make this go away? I'm running ubuntu on Dell Inspiron 3537.
Seth
  • 59,332
I managed to fix this by rolling back from systemd to upstart. More info here:
https://wiki.ubuntu.com/SystemdForUpstartUsers
Permanent switch back to upstart
Install the upstart-sysv package, which will remove ubuntu-standard
and systemd-sysv (but should not remove anything else -- if it does, yell!),
and run sudo update-initramfs -u. After that, grub's "Advanced options"
menu will have a corresponding "Ubuntu, with Linux ... (systemd)"
entry where you can do an one-time boot with systemd.
If you want to switch back to systemd, install the systemd-sysv and ubuntu-standard packages.
I had the same problem in my Manjaro, searching I found a post in a reddit forum of Arch Linux.
Here is the solution that works for me https://www.reddit.com/r/archlinux/comments/4bawf7/a_stop_job_is_running_for_session_c2_of_user/d17th3u
You need to ubuntulize it:
Install watchdog
# pacman -S watchdog
And then start the service at boot:
# systemctl enable watchdog.service
Start the service to don't see the message any more
# systemctl start watchdog.service
I create a gist for this https://gist.github.com/dianjuar/98d02af4050dc2df8ae6f18695d44ca3
