I have one file Film.MPG. Which is 720P and 50 frames per second. When i play the file using gst-launch playbin uri=file:///tmp/final.mpg it does not work. But it works with Mplayer/VLC. I noticed that I can convert the file and it also works but then I lose quality.
So my question is. How do i use ffmpeg to convert File.MPG to better quality File.AVI or other formats, so that I have balanced video/audio or almost same working.
Follow up:
by doing this its working: ffmpeg -sameq -i filmfr2.mpg filmfr2.avi
hhlp
  • 42,872
Increasing the bitrate while preserving resolution and playback fps may result in a bigger file but you can save much of the quality. It's about to try it. There are also several GUIs for ffmpeg, such as the Mobile Media Converter, mentioned over here for a question similar to this: How can I maximum compress video files?
Remember, this won't increase the quality of your video, but this can help you to preserve your current quality.
I hope this gives you a clue on how to run your test, even if this doesn't answer your question.
I expect downvotes to this answer, let's see how much do I harvest this time.
Good luck!
If the file does not play under gst-launch, then you don't have the GStreamer elements necessary to play the file installed.
I would suggest trying to play the file under totem (which uses the GStreamer framework). If there are any missing elements, it will pop up a window prompting you to install the packages necessary to play the file. Once you've done that, the file should play in totem and any other GStreamer application (including a custom gst-launch invocation).
