I was trying to map 'q!' to 'Q!' in .vimrc ? I tried the following but not working. :command Q! q! Please provide any suggestion to mitigate this issue. Thank you.
Asked
Active
Viewed 2,131 times
You just have to give
:command Q q
Similarly, you can do for other commands like,
:command WQ wq
:command W w
muru
- 207,228
This worked perfectly for me:
:command-bang Q q<bang>
From vim's help (:h command-bang):
Special cases :command-bang :command-bar
:command-register :command-buffer
There are some special cases as well:
-bang The command can take a ! modifier (like :q or :w)
and
Replacement text
The replacement text for a user defined command is scanned for special escape
sequences, using <...> notation. Escape sequences are replaced with values
from the entered command line, and all other text is copied unchanged. The
resulting string is executed as an Ex command. [...]
The valid escape sequences are
<bang> (See the '-bang' attribute) Expands to a ! if the
command was executed with a ! modifier, otherwise
expands to nothing.
